User Tag List
Similar Threads
  1. Bleed issues on mug wrap press
    By tydonk in forum Mug Presses & Ovens
    Last Post: 07-11-2013, 07:51 PM
  2. MUG Letter Bleed
    By JackB in forum Mug Presses & Ovens
    Last Post: 20-06-2013, 09:38 PM
  3. Insert paper for full bleed t-shirts
    By DigitalTed in forum Clothing
    Last Post: 04-12-2012, 06:20 PM
  4. sub ink bleed through paper problem
    By logobear in forum General Dye-Sub Chit Chat
    Last Post: 28-09-2011, 09:57 AM
  5. Full bleed sublimation tee by Conde
    By Justin in forum Press Releases/Announcements
    Last Post: 06-05-2010, 12:30 PM
Results 1 to 3 of 3
  1. #1
    Member
    Join Date
    Nov 2014
    Location
    Pocklington
    Posts
    77
    Downloads
    3
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Bleed on plates and mugs
    Using a 3d vacuum heat press, I get a bit of bleed on some of my plates, is this because I'm cutting exactly round the circle and not leaving a few mm of paper round them or is there another reason please?
    Also with my mugs some come out perfectly but others either leave a small mark where the tape has been or leave a bluish tint to the mug outside where the paper is attached which is obvious to see due to it being white under where the tape has been,
    does anybody have any advice on how to rectify these problems please?
  2. #2
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,387
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    Plates, I suspect it is exactly as you say, try leaving a good few MM of paper.
    The tint is dye sub gas "escaping" and then settling wherever it lands. This is normally caused if you are bleeding off the top/bottom and have some exposed ink or if you are using thin paper or the silicon style wraps. I use the silicon wraps and I have found that firstly you need to make sure they are very clean (by leaving them in a hot oven for 30+ minutes) and also make sure you have the vacuum turned on when you are printing a mug.
    Good luck!
  3. #3
    Member
    Join Date
    Nov 2014
    Location
    Pocklington
    Posts
    77
    Downloads
    3
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks pal.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
