User Tag List
Similar Threads
  1. DF30 Swing Away Press
    By Maggie in forum Heat Presses
    Last Post: 27-02-2015, 08:36 AM
  2. Just got a swing press
    By SilentAlf in forum Heat Presses
    Last Post: 08-09-2013, 06:04 PM
  3. Wanted A2 Swing away press
    By JMugs in forum Buy It, Sell it, Give it away!
    Last Post: 05-08-2013, 10:25 PM
  4. Swing Press Question
    By Kahboose in forum Heat Presses
    Last Post: 11-07-2012, 09:13 AM
  5. clamshell press vs. Swing away
    By Paul in forum Heat Presses
    Last Post: 30-06-2011, 06:12 PM
Results 1 to 3 of 3
  1. #1
    Member Bob700's Avatar
    Join Date
    Jan 2010
    Location
    Glasgow
    Posts
    446
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    40 x 40 Swing away press
    Hi
    I have a 40 x 40 swing away press made by Joy's, it's a really good press but my problem is, I've been forced to move back into my loft but the press will not go through the hatch, is there any way it can be taken apart as otherwise I will have to get rid of it and I'd rather keep it, any help/advice would be welcome.
    Thanks Bob
  2. #2
    Senior Member
    Join Date
    May 2012
    Location
    Plymouth
    Posts
    1,895
    Downloads
    0
    Uploads
    0
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    The answer is "Yes" all presses will come apart, the question is how?
    There will be retaining lock nuts somewhere. Some presses have the knob you turn on top with a lock nut directly under that (as per my small Cheap chinese flat press). Hold the lock nut undo the knob, undo the lock nut, lift the top platten off.
    Or you may find the lock nuts are under the the top of the swivel point (as per my medium Shultz press) once undone lift the platen off (heavy) , or accessible right at the base with locking grub screws and a bearing as per my large Pressmech where you then lift the top platen and the adjusting bar out in one go (very heavy!).
    Hope that helps with where to look.
    There will of course be other variations.
    Janners
  3. #3
    Join Date
    Jan 2010
    Location
    Glasgow
    Posts
    446
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the info
Posting Permissions
  • You may not post replies
  • You may not edit your posts
