User Tag List
Similar Threads
  1. suitable printer
    By themojo in forum Printers
    Last Post: 16-12-2014, 06:59 AM
  2. Is this suitable
    By Charlie_ in forum Heat Presses
    Last Post: 28-09-2012, 04:47 PM
  3. Ciss for sx445 suitable for sub ink?
    By Starfront in forum Printers
    Last Post: 28-02-2012, 07:48 PM
  4. Bags suitable for Sublimation
    By draig in forum Sourcing New Items
    Last Post: 04-01-2012, 10:37 PM
  5. Counter Mats
    By Justin in forum Sourcing New Items
    Last Post: 05-03-2010, 10:26 AM
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,385
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    My ovens hold 12 and are done in 14 minutes. I have enough wraps so 12 are ready to go in when 12 come out, one oven = 48 an hour.
  2. #12
    Premium Member
    Join Date
    Nov 2011
    Location
    Bishop Auckland, County Durham
    Posts
    4,280
    Downloads
    0
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    3 Thread(s)
    We have 4 single presses, and I can get 36 mugs done in an hour, we are now looking at ovens/wraps to up this rate.
    @Social - which oven and wraps are you using?
  3. #13
    Member
    Join Date
    Dec 2014
    Location
    Little Chesterford, Essex
    Posts
    208
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for all the replies, I did wonder about the maths regarding mug press and oven. I shall get a cheap halogen from www.coopersofstortford.co.uk (the store is local to me) and give them a go. I see timing varies here from 14 mins to 23 mins so that will be an interesting experiment when I start. I think another consideration is the overall running costs over time ie replacing press blankets at £60 + a time = 2 halogen ovens - electricity usage (1400 watts - 450watts for press). I suppose this is all only relevant for volume work and I'm some way off of that. I just wanted to see if ovens would be better for all over coverage prints and getting closer to the handle - just my enquiring nature)
    My wraps came yesterday (green ones) £16.00 all in for 3, look easy to use, I'm looking forward to trying out.
  4. #14
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,385
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    Standard green ones found everywhere....
    http://www.subliblanks.com/10oz-11oz-mug-clamp
    They are perfect and have enough stretch in them to be easily applied.
    You can get a lot closer about 5-8mm from the handle depending on the design and how adventurous you are :-)
  5. #15
    Junior Member
    Join Date
    Aug 2015
    Location
    Aylesbury
    Posts
    4
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What sort of oven are you using to get 12 in, a benchtop convection oven?
  6. #16
    Premium Member
    Join Date
    Nov 2011
    Location
    Posts
    4,280
    Downloads
    0
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    3 Thread(s)
    Can't remember the model number, but we got a standard full size oven from Argos fir about £100
    key things about it are firstly being fan assisted, so the temperature is consistent throughout the oven chamber, and there's two heating elements, one top and bottom. Also, power wise it only draws around 2000 watts, so runs on s normal 13 amp plug comfortably.
    We have baking trays the mugs sit in, which take 12 mugs each, so 24 mugs at a time.
    Using a temp controller and heat probe we had in our heat press spares, running as just a thermometer, as not had time to rewire the oven for it to control things, but it reads 220 degrees, and we leave in for 25 minutes
  7. #17
    Premium Member
    Join Date
    Nov 2011
    Location
    Posts
    4,280
    Downloads
    0
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    3 Thread(s)
    ... Oh, and it's sitting on top of our workbenches, so is a bench top oven! ;-)
  8. #18
    Junior Member
    Join Date
    Aug 2015
    Location
    Aylesbury
    Posts
    4
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi pisquee
    Thanks for this.
    Are you getting consistent results from a setup like that? I have been battling with halogen ovens but find the temperature differences create problems with inconsistency. The outside of the oven tends to be +15 degrees hotter than the centre and the top hotter than the bottom. It's a pain. It sounds like you have got a pretty decent constant temperature with that oven, yes?
    Gary
  9. #19
    Premium Member
    Join Date
    Nov 2011
    Location
    Posts
    4,280
    Downloads
    0
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    3 Thread(s)
    Yes, happy with the results, especially considering how cheap the actual oven was.
    figured instead of 'cheapy' halogen type oven, it wasn't really much more money to get a full sized fan assisted domestic kitchen oven.
    Without the fan on, the cooking time increases by 10 minutes, but there's too many mugs not printed well enough.
    The main problem is the green silicone wraps aren't always tight enough on our mugs - they aren't all exactly the same size, so am now thinking we're gonna have to invest more money into better quality wraps, preferably adjustable, rather than 'one size fits all' which don't.
  10. #20
    Premium Member
    Join Date
    Nov 2011
    Location
    Posts
    4,280
    Downloads
    0
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    3 Thread(s)
    This is what we got, but ours was branded as Bush (same model number) and didn't have the clock.
    http://www.argos.co.uk/static/Produc...er/2419235.htm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
