If you already use Trupix paper then our Instant Dry paper for dye sublimation is a great alternative that prints and transfers just as well and is cheaper per sheet at just 10.9 pence per A4 sheet.
It's a great all round paper, exceptionally quick drying, which means it's ideal for the faster Ricoh printers. You can also print on either side, so no worrying about which way to load the sheets into your printer!
In performance terms it prints and transfers exactly the same, if not better than Trupix and can be used for sublimation printing onto most substrates (although it is not suitable for Acrylic or cheap plastics).
http://www.isub-supplies.co.uk/inks-...00-sheets.html
If you haven't ever ordered from ISub Supplies before then use the discount code 'free-delivery' at checkout to get free shipping!
What's not to like??
