User Tag List
Similar Threads
  1. HELP!!!! - Problem with WoW 7.7
    By Gygafo in forum Printing Problems/Issues
    Last Post: 25-08-2015, 05:55 PM
  2. mug problem
    By guarddog14 in forum Mug Presses & Ovens
    Last Post: 14-11-2013, 01:16 AM
  3. Mug print problem
    By nigelt in forum Printing Problems/Issues
    Last Post: 04-08-2013, 12:12 AM
  4. last problem .... i hope
    By Lornem in forum Mug Presses & Ovens
    Last Post: 25-08-2011, 11:29 AM
  5. One more problem ..... Any ideas ?
    Last Post: 22-08-2011, 09:48 PM
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Junior Member
    Join Date
    Jun 2015
    Location
    Edmonton
    Posts
    6
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This may seem trite but I had a similar problem with mine. And all I did was check the exhaust hose coming out of the back of the machine and it wasn't sitting in the "hole" properly. So I made sure and still make sure that it is sitting in the "hole properly" because that is part of your vacuum seal too.
    Hope that makes sense....
  2. #12
    Junior Member
    Join Date
    Oct 2015
    Location
    London
    Posts
    2
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks larsly888, I've checked the hose, it's not that. Are there any uk suppliers who sell spares for these machines. Looking for a new motor.
  3. #13
    Junior Member
    Join Date
    Sep 2016
    Location
    Guildford
    Posts
    8
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ArtyGamer View Post
    First thing you want to do is to remove the suspended tray (the one you'd take out for doing mugs) and check the hose at both ends for cracks, splits, or holes. If you find any, just cut them off to leave a clean, sharp edge again and re-attach. Put your tray back in and try the suction again. If it's still not pulling the silicon sheet clear then you need to unplug the machine, flip it upside down, use a long screwdriver, and open it up. It's entirely possible that the hoses going into the vacuum pump itself may have become cracked or split so you'd be best to check that first. You can test it while it's still sitting open (be careful not to touch anything electrical inside it, though) by starting the suction up and putting your finger over the end of the hose which attaches to the bottom of the suspended tray. If it sucks properly and the vacuum display goes into the red then you've solved it. If it doesn't, then you need to REALLY open it up and go to the hose which attaches to the underside of the bottom tray.
    This takes much longer, and can be a little fiddly. The first time I had a hose issue it was with one of the ones attached to the pump itself, and it was easily fixed by cutting the hose a little but there's not much margin for error on those ones. The second time was with the hose underneath the bottom tray, and that was a real pain to deal with. Cut it and re-attached it though, and all was well. Every other time (which was practically weekly for a while) was with the hose that you can see when you lift up the suspended tray. It would tend to crack where it attaches to the suspended tray, but sometimes it would break at the base instead.
    After having to cut the hose far too regularly for my liking, I started buying different hoses to try them out. In the end, I replaced ALL my hoses using the one from the link below. You can't use the screw to hold it in place as it's too thick for it to properly fit, but the hose itself is tight enough that it pushes on and doesn't come off. Now, my entire machine uses this thicker hose and I've not once had to cut it again. Not sure how long it's been, but my guess is that it's at LEAST a year since I've had any hose issues, thanks to this reinforced hose:
    http://www.autosiliconehoses.com/3mm...lue-black.html
    Hope this helps
    Hi
    How do you open up the back of the machine? I have flipped it upside down and unscrewed the bolts and screws but it doesn't seem to open up anything?
    Peggy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
