User Tag List
Similar Threads
  1. Is it worth it?
    By MrMuggins in forum General Dye-Sub Chit Chat
    Last Post: 25-03-2016, 10:25 AM
  2. upgrading my laptop O/S to W8 Pro
    By bigj2552 in forum Take a Break
    Last Post: 05-02-2013, 01:17 PM
  3. Replies: 11
    Last Post: 03-11-2012, 10:11 PM
  4. Richo GX5050N- vertical lines
    By yoirqu in forum Printing Problems/Issues
    Last Post: 07-12-2010, 04:26 PM
  5. Richo GelSprinter Aficio GX 5050n Colour problems
    By Iain4246 in forum Printing Problems/Issues
    Last Post: 27-02-2010, 12:15 AM
Results 1 to 9 of 9
  1. #1
    Member Reading-Print's Avatar
    Join Date
    Mar 2015
    Location
    Wokingham
    Posts
    126
    Downloads
    14
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is it worth upgrading from A4 to A3 Richo printer
    Hi there,
    At the moment I have a Richo SG3110DN A4 printer for doing sublimation onto t-shirts, and I am just wondering is it worth it to upgrade to a Richo SG7100 A3 printer?
    Regards
    Damian
  2. #2
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,384
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    Personally I would bypass the A3 and go for a wide format.
    Considerably cheaper to run (even if you stick with Sawgrass ink), so you will get your money back at some point (depending on how much you print obviously).
  3. #3
    Join Date
    Mar 2015
    Location
    Wokingham
    Posts
    126
    Downloads
    14
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi socialgiraffe
    I have Roland bn-20 wide format printer in my set up. So you would suggest giving A3 a Bypass
    Sent from my SM-G900F using Tapatalk
    Using Ricoh Aficio A4 sublimation printer, Epson 1500w A3 sublimation printer, Xpres heat press, ST3042 3D sublimation machine
  4. #4
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,384
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    Personally I would say yes and go for a wide format sublimation printer instead.
    I had a Ricoh A3 which I rarely used, great printer, just did not have the call for A3. With a wide format sublimation I can justify the purchase because, not only does it give you a larger print area to offer, but also a much cheaper price per print.
    I have a Roland VS and so know how much cheaper it is to run with regards to ink.
    I must admit I do like the look of the Sawgrass wide format offering, but I have a feeling I will be shot for saying that on here as there are people who know a considerable amount more about wide format sublimation than I ever will :-)
  5. #5
    Member
    Join Date
    Dec 2015
    Location
    FR
    Posts
    173
    Downloads
    2
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you want to reduce your cost per print, I recommend you get the Epson 1500W, it uses ArTainium (by Sawgrass) ink which is way cheaper than SubliJet, and it does produce better prints. Only thing is maintenance, if you don't print for a while your heads are clogged. Just my 2 cents
  6. #6
    Member
    Join Date
    Jan 2013
    Location
    Earth
    Posts
    976
    Downloads
    7
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use a 1500w along with a CISS and have no problems with it! I even managed NOT to take off the lid to the cartridge holder, just made a slight modification, and the tubes run perfectly!
  7. #7
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,384
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    That is my biggest concern on them. If my Ricoh blocks (not that they ever have), I will just throw it away and get a new one. You can not do that with a £2000 machine though
  8. #8
    Member
    Join Date
    Dec 2015
    Location
    FR
    Posts
    173
    Downloads
    2
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, knowing that removing the lid and using other inks (than Epson) voids the warranty. So if your heads are clogged (or have any other problem) you have to buy a new one, and it does cost (in France) €265, you chose.
  9. #9
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,384
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    Another reason why I fancy the Sawgrass 24 inch machine. At least everything is covered by them then. But you can purchase nine Epsons for the same price
Posting Permissions
  • You may not post replies
  • You may not edit your posts
