User Tag List
Similar Threads
  1. For Sale Adkins 20 x 15 swing away heat press
    By pressfx in forum Buy It, Sell it, Give it away!
    Last Post: 25-05-2016, 11:55 PM
  2. Swing heat press advice
    By bianca in forum Heat Presses
    Last Post: 23-05-2016, 11:19 PM
  3. For Sale Secabo TS7 swing away heat press
    By WePrintForYou in forum Buy It, Sell it, Give it away!
    Last Post: 03-11-2014, 09:13 PM
  4. Best value for money swing heat press ?????
    By Burrelly7 in forum Heat Presses
    Last Post: 20-09-2012, 01:28 PM
  5. Wanted Swing Away 38 x 38 Heat Press
    By personalised_sublimation in forum Buy It, Sell it, Give it away!
    Last Post: 04-05-2012, 05:57 PM
Results 1 to 7 of 7
  1. #1
    Junior Member
    Join Date
    Jun 2016
    Location
    Lincoln
    Posts
    14
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Getting T shirt design straight on swing heat press.
    Hi everyone, I hope someone can help this newbie.
    I lay a t-shirt out on the heat press but have real difficulty getting the t-shirt straight and centred to get the design in the right place, Can I stick the design to the t-shirt using heat proof tape or is there a foolproof way of doing it.
    Divine Vinyls
    Guest
    I do all mine by eye, not sure if proper way or not but works for me, i then pull under arms up and ensure i have the same space on each side. To start with lay your tshirt flat and place vinyl on and then transfer to press?
  3. The Following User Says Thank You to Divine Vinyls For This Useful Post:
    Phil47 (01-07-2016)
  4. #3
    Member
    Join Date
    Mar 2015
    Location
    Oxfordshire
    Posts
    532
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try your idea but perhaps practice a lot lining t shirt up on the press, equal bits hanging off the sides, shoulders lined up at top squarely, stick your logo on with tape then lift it up and check for square, after time you will get the knack but it is a pain as you will find t shirts are not perfectly made and sometimes folded oddly so give then a shake out first
    Mark
  5. #4
    Member
    Join Date
    Nov 2009
    Location
    Peterhead, Aberdeenshire
    Posts
    264
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just place a large ruler from armpit to armpit and place whatever your applying central. Do them and tape it so you can do multiple shirts before you start pressing.
  6. #5
    Senior Member
    Join Date
    Apr 2012
    Location
    Vale of glamorgan
    Posts
    1,113
    Downloads
    3
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    some times i pre press with the tshirt folded in half, this gives you a line down the centre of t-shirt, then fold your design in half and you have the middle of design.
  7. #6
    Senior Member
    Join Date
    Jan 2012
    Location
    Germany-NRW
    Posts
    1,281
    Downloads
    2
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Once the t-shirt is square on the press ( as explained above) I have a couple of pieces of stout card,cut square and the same width as the press. These are cut to depth for a front or back print.
    Lay it on the shirt from the collar down, and line up the print using this. Every shirt will be printed in exactly the same place.
    If your vinyl is the non sticky type then lay a piece of baking paper on top to hold it in place.
  8. The Following User Says Thank You to Earl Smith For This Useful Post:
    AletB (04-07-2016)
  9. #7
    Member
    Join Date
    Oct 2015
    Location
    Lymm
    Posts
    374
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I usually just measure either edge of whatever is to be transferred to make sure it's central (armpit to armpit), then I use a ruler and lay it on the transfer/vinyl and check that with the base of the shirt to see if the ruler is straight, if the ruler isn't straight the transfer isn't straight either. Works for me
Posting Permissions
  • You may not post replies
  • You may not edit your posts
