Just having a read through the vinyl cutter section to see if I could get some answers to my long time problem.
I have been having this issue for a while an I'm unable to find a cure myself.
Thing is, it seems as if where the cutter starts to cut a font/shape and where is finishes it's not cutting all the way. I have tried the overcut which does overcut but if you look closely you can see a very small section as if its started to cut to early and by the time its finished the cut on the font/shape they don't meet up.
I hope this makes sense as it's the best I can explain. I am using flexi as my cutting program.
I have kind of given up on the machine because of this and now stick to my cameo but i'ts a new machine and a bit of a waste just sitting there as it would save so much time if I could get it working properly.
The machine does this with both sign vinyl and clothing vinyl (worse on clothing vinyl but I gather that's because it's softer)
Hope somebody can help.
