User Tag List
Similar Threads
  1. sunangel not transferring cleanly
    By soulclaimed in forum Transfers & Transfer Papers
    Last Post: 17-02-2016, 08:31 PM
  2. Problem with image not transferring onto mug
    By Simong12 in forum Printing Problems/Issues
    Last Post: 20-01-2015, 01:34 PM
  3. Problems with magenta transferring on mugs. Any advice appreciated!
    By benson in forum General Dye-Sub Chit Chat
    Last Post: 21-07-2014, 07:04 AM
  4. (Newbie)Image not transferring
    By Rian in forum Printing Problems/Issues
    Last Post: 17-08-2013, 05:25 PM
  5. transferring small text?
    Last Post: 31-03-2013, 05:03 PM
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Junior Member
    Join Date
    Aug 2016
    Location
    יקנעם עילית
    Posts
    10
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The protective paper is only to catch the ink steams that releases in process so the heat press will not get dirty
    Also, I'm not sure but it might also keep the ink from burning, till I got this combination of process I got some burned images, you can see it on the brown tons the most
    Anyhow, using this setup I'm getting extremely good results each time
    I apply high pressures not medium so the image will be good all over the image, even at the edges of it
    With medium pressure I got some weak printing on some spots like it doesn't transferred properly
    Here is the results you should get
  2. #22
    Junior Member
    Join Date
    Aug 2016
    Location
    יקנעם עילית
    Posts
    10
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So, maybe try to adjust the pressure
    I'm using a real high pressure like little more and the mug is going to crack
    Your faded print looks like the misprints I was getting in some areas
    Also, check the paper, does it have a lot of ink left on it ?
    If do it's only heat, time, pressure factors
    Took me 24 mugs to get this results :) so keep it going
  3. #23
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,591
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    Insted of high pressure, try incressing your time. High pressure doesn't help.
    <-- How To Print Stuff BLOG
  4. #24
    Senior Member
    Join Date
    Jun 2014
    Location
    Devon
    Posts
    1,051
    Downloads
    2
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've found that HIGH pressure shortens element life and can lead to orange peel effect.
  5. #25
    Junior Member
    Join Date
    Aug 2016
    Location
    יקנעם עילית
    Posts
    10
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What do you mean by "shorten elements life" ?
  6. #26
    Senior Member
    Join Date
    Jun 2014
    Location
    Devon
    Posts
    1,051
    Downloads
    2
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Over tightening the element belt seems to make the heater elements fail quicker some manufacturers warn against this.
    But one man's medium pressure is another's super tight, bit like a press what I term heavy pressure the wife cant even close the press and if I close it at that pressure then it nearly knocks her teeth out when she opens it..... hence the reason we upgraded to a pneumatic 40 x 50 press, easy peasy press two buttons simultaneously and hey presto job done, also auto opens when time is up....... But I digress.
  7. #27
    Junior Member
    Join Date
    Aug 2016
    Location
    יקנעם עילית
    Posts
    10
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    For now my press doesn't have any issues
    But I'm not using it much since my web isn't ready yet
    I just found that if the pressure not high I'm getting some misprints at the edges left and right
  8. #28
    Banned
    Join Date
    Sep 2013
    Location
    Newcastle upon tyne
    Posts
    552
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    pressure enough so you can only just move the mug with a lot of force any more then the element will start to mishape and you can cause microcracks in the wires that provide the heat.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
