User Tag List
Similar Threads
  1. 3d mini vacuum press
    By ivansmagic in forum Mug Presses & Ovens
    Last Post: 01-10-2015, 05:14 PM
  2. St-1520 3d mini sublimation
    By serec in forum 3D Sublimation
    Last Post: 09-09-2015, 12:15 PM
  3. Vacuum on 3d mini not working !!!!
    By ammemcgxx in forum General Dye-Sub Chit Chat
    Last Post: 15-04-2015, 04:45 PM
  4. Mini 3D Vacuum
    By bms in forum 3D Sublimation
    Last Post: 04-01-2015, 08:35 PM
  5. Mini 3d vacuum - 3 dashes
    By wessy83 in forum 3D Sublimation
    Last Post: 05-11-2014, 08:27 PM
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Junior Member
    Join Date
    Oct 2016
    Location
    Newbrighton
    Posts
    24
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Poor vacuum st-1520 3d mini sublimation repair
    Evening all. Due to very poor read on vacuum pressure gauge I've done a little digging and found the rubber membrane has a small hole/tear. The machine is a st-1520 3d mini sublimation machine or equivalent. The hole is only a mill or so and wandered if anyone knows if it can be repaired short term and where to buy a replacement.?? Many thanks
  2. #2
    Member
    Join Date
    May 2013
    Location
    London
    Posts
    628
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    HI Buddy ..yes you can repair them short term But for that you need a slicon gum tube (little one u can buy from B & Q ) ..If its a small hole just apply the slicon to cover it ..But if its bigger tear you have to patch it with a another slicon meterial (I use the damaged ones ) ..This worked for me on St3020 and ST2030 so I am sure it should work on ur one too...
  3. #3
    Junior Member
    Join Date
    Oct 2016
    Location
    Newbrighton
    Posts
    24
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi ravisteam.thanks for the responce. It's a tiny hole. The only way I found it was to suck on the nozzle and it opened slightly and was about 1mm long and hair line thick. I sucked the nozzle and it started to vacuum then put and finger on the hole and it sicked right in . Will go to b and q to get a tube tomorrow and give it a try. Where do you get your spares from as I'm struggling to find one?
  4. #4
    Member
    Join Date
    May 2013
    Location
    London
    Posts
    628
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by De8n View Post
    Silicon tube will do the job ..Always keep few spare ones as these get burst all the time ..I dont have your model but I can order few for you if you want ..Might take about 10 days tho ....Ill let u know soon ..
  5. #5
    Junior Member
    Join Date
    Oct 2016
    Location
    Newbrighton
    Posts
    24
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Morning Ravi. Yea if you could give me a roughy idea on costing please ��. I've hit google in search of silicon gum as per your first responce but can't find anything. Is it just ordinary house hold sealant I'm looking for ? Wasn't sure as didn't think it was heat proof.
  6. #6
    Premium Member
    Join Date
    Jun 2014
    Location
    Bridgnorth
    Posts
    314
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Could you use a cycle inner tube repair kit ?
  7. #7
    Member
    Join Date
    May 2013
    Location
    London
    Posts
    628
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    I used a slicon tube from B&Q just a small tube size of a toothpaste. ..it's transparent slicon gum...only £3. Something. .after apply it u need to keep it over 12 hrs to dry .....I am not sure about cycle tubr repair gum ...slicon is heat proof anyway. ..
  8. #8
    Junior Member
    Join Date
    Oct 2016
    Location
    Newbrighton
    Posts
    24
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks Ravi. I'll head to b and q this morning and get a tube . Suppose it will always come in handy if it happens again too :)
  9. #9
    Member
    Join Date
    May 2013
    Location
    London
    Posts
    628
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Cost of thode sheets ?? I was going to do a order and and if they have them I can order it for you ....they are about £5 -10 .....also u can check on ebay I saw those selling for £15 ....
  10. #10
    Junior Member
    Join Date
    Oct 2016
    Location
    Newbrighton
    Posts
    24
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm not sure what's it's called to look on eBay so any idea what they would be listed as Ravi?? I've been into B&Q and can't find anything called silicon gun. I explained what I wanted to the guy who worked there and he said a Evo stick serious glue should do the trick. It sticks to rubber and says a thick layer will fill gaps and form a flexible bond
Posting Permissions
  • You may not post replies
  • You may not edit your posts
