Hello there,
I've been noticing that some items get a residue stuck to either the surface of the mug or the edges of a 3D case. It's a white colored residue that can be scratched, like a stuck dust.
The paper - ink combo seems to be reason, since I can see the missing part of the "surface" (or whatever the name of the treatment on the printable side is). But it's not on every pressed item. On cases it's about 50% of the times, and on mugs around 20%, with consistent temp pressure and time settings. It can be easily scratched to remove it, but cases get damaged in the process.
Has anyone had this issue or may be aware of a solution?
Thanks guys
Using:
Ricoh 3110 and Sublijet-R
Texprint-R paper
Powerdriver v4
