User Tag List
Similar Threads
  1. 0.5mm Aluminium
    By ArferMo in forum Printing Problems/Issues
    Last Post: 20-01-2015, 09:16 PM
  2. Data sheet required for aluminium
    By Niki MM in forum Printing Problems/Issues
    Last Post: 08-10-2014, 12:46 PM
  3. outside durability aluminium
    By arti in forum General Dye-Sub Chit Chat
    Last Post: 06-01-2014, 07:41 PM
  4. aluminium printing
    By smitch6 in forum General Dye-Sub Chit Chat
    Last Post: 02-09-2011, 10:31 AM
  5. Me again - Aluminium Coaster
    By gstk in forum Sourcing New Items
    Last Post: 28-10-2010, 11:42 PM
Results 1 to 9 of 9
  1. #1
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Drilling Aluminium sheet ...
    [User Deleted]
  2. The Following User Says Thank You to webtrekker For This Useful Post:
    Skarekrow (21-11-2016)
  3. #2
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,369
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    I tried drilling 1mm aluminium. It can be dangerous to hands and eyes, so I get it milled instead...much easier.
  4. #3
    Member
    Join Date
    Nov 2016
    Location
    Truro
    Posts
    67
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I find the same thing when I am drilling into dibond (aluminium composite sign board) It tend to happen if I apply too much pressure to the drill.
    Doesn't the rag get caught up in the drill?
    Premium Member
    Join Date
    Jun 2014
    Location
    Bridgnorth
    Posts
    314
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not sure what size hole you need but I purchased a hole punch set for producing my own bookmarks. The trick to cutting thin sheet is to sandwich & clamp it between two sheets of ply, drill a pilot hole and progressively enlarge. You can also use a cone cut which is as the name suggests a conical drill with a single flute that will create any sized hole up to its maximum diameter. They come in different sizes. A third method is to use a hole saw but you wont get a clean finish.
    My choice would be a conecut and support the sheet on ply. Ideally you would use a pillar drill and set the stop to the required diameter. It is easy to over cut. They are not expensive and worthwhile if you intend to make more clocks.
  6. #5
    Member
    Join Date
    Mar 2015
    Location
    Oxfordshire
    Posts
    532
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Good tip and nice of you to share it.
  7. #6
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    [User Deleted]
  8. #7
    Member
    Join Date
    Nov 2016
    Location
    Truro
    Posts
    67
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ah so it is a tiny piece of cloth that can spin with the drill.
    That makes sense.
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    [User Deleted]
  10. The Following User Says Thank You to webtrekker For This Useful Post:
    Skarekrow (22-11-2016)
  11. #9
    Member Developit's Avatar
    Join Date
    Mar 2014
    Location
    Perth Western Australia
    Posts
    67
    Downloads
    5
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have been drilling holes in aluminum sheets with a fiskars hand drill. Clamp metal to bench and drill. Simple and easy to control. My husband calls it my "girls drill" but it's all I need to do this.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
