Hi
I'm just getting back into mug printing and in the past I stuck with BMS for my mugs because I trusted them not to fade but I was thinking of Xpres 3015 mugs does anyone have an opinion on Xpres mugs with regards to fading.
Hi
Do you mean XP5013?
I only use XP5013 now, had a fair few issues with the BMS mugs and swapped just before I started buying in larger bulk. Not had a bad one yet, recently started playing with top to bottom prints again (Usually avoid these) but results so far are spot on.
Lucifax (04-01-2017)
both seem fine to me. both CLAIM wash fast .... but not tested, - who does 1000 wash cycles to personallly test?
Yes Justin I meant the XP5013, I'll give them a try first, the reason I'm asking is that I have a BMS mug I printed years ago and it's as good today as the day I printed but I do recall the last time I used them there was a couple of issues
I am currently using the Xpres 5013 and also have used the BMS RN's in the past. Not had any issues from customers or clients on inks fading so far.
