User Tag List
Similar Threads
  1. Silicone mug wraps for latte mugs really expensive!
    By brightday83 in forum Mug Presses & Ovens
    Last Post: 14-11-2016, 07:32 PM
  2. Equipment, are the expensive kits worth the extra money?
    By Bob @ Prestige in forum General Dye-Sub Chit Chat
    Last Post: 30-11-2014, 09:32 PM
  3. quickest way from leicester to devon??
    By soulclaimed in forum Take a Break
    Last Post: 14-05-2013, 11:53 PM
  4. Advice on bulk orders
    By dj_doubler in forum General Dye-Sub Chit Chat
    Last Post: 25-05-2011, 03:28 PM
  5. When does a blank placemat become too expensive?
    By bms in forum General Dye-Sub Chit Chat
    Last Post: 26-02-2011, 05:43 PM
Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
  1. #31
    Member
    Join Date
    Dec 2016
    Location
    Abergavenny
    Posts
    257
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I must admit I've not had a problem with gas and ink in my oven when I print. I tend to put a piece of paper between the transfer and the wrap which seems to trap any leaking ink.
  2. The Following User Says Thank You to Customprintwales For This Useful Post:
    Maidiniceland (19-02-2017)
  3. #32
    Member
    Join Date
    Oct 2016
    Location
    Durham
    Posts
    163
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by pw66 View Post
    If you spend a bit more money you will get one were you have the option of turning the fan on or off. If you suck the gas out you are also sucking the heat out with it, causing more problems. The only way to reduce the gas successfully will be to reduce the number of mugs in the oven.
    The benefit of a commercial oven is that you can find one with a higher power rating than with a domestic oven, theoretically giving a more stable temperature and heat distribution, meaning you shouldn't need the fan. You can go up to about 3kw on 13amps - a domestic oven is unlikely to be much more than 2kw.
    Thanks for your reply.
    I guess, my thinking here is, if the only way to reduce the gases in the oven is to reduce the number of mugs in there... wouldn't that defeat the objective of having an oven? (To be able to press a lot of mugs at one time)
  4. #33
    Member
    Join Date
    Oct 2016
    Location
    Durham
    Posts
    163
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Customprintwales View Post
    What kind of oven do you use?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
