As you may have seen in the printer problem sub forum im having issues when using any ICC profiles (no problems when not using colour management) with banding through magenta.
So I have been advised to change to Epson as magenta banding is a known issue(?) with the Ricohs
From searching on here the Epson 7110DTW seems to cause lots of problems (clogging mainly) so I'm reluctant to switch from my beloved 3 year old Ricoh thats worked flawlessly up until now for something that is reported to have a fair few regular problems.
Has anyone else gone from Ricoh to Epson? How has it been? A mistake or not?
I could buy another 3110DN, however if its true that they have unfixable magenta banding problems it doesn't seem like a wise move, so as you can see, im kind of stuck between clogged print heads or banding magenta!
Help!
