User Tag List
Similar Threads
  1. Cutting Vinyl rolls for cameo
    By IrishPrint in forum Vinyl Cutters
    Last Post: 01-03-2017, 01:37 AM
  2. Newbie Setup
    By leehyde30 in forum General Dye-Sub Chit Chat
    Last Post: 02-01-2017, 01:13 PM
  3. cameo cutting mats cleaning tips
    By paul 44 in forum General Dye-Sub Chit Chat
    Last Post: 23-12-2016, 12:20 AM
  4. JPSS cutting with a cameo portrait
    By paul 44 in forum Transfers & Transfer Papers
    Last Post: 27-01-2016, 11:48 PM
  5. Contour cutting with cameo
    By Maup in forum Vinyl Cutters
    Last Post: 01-10-2014, 09:43 AM
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Member
    Join Date
    Nov 2012
    Location
    northamptonshire
    Posts
    825
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can you give a link to what vinyl you have been using
  2. #22
    Member
    Join Date
    Sep 2016
    Posts
    167
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I got some A4 vinyl sheets from a company called signmakingandsupplies.co.uk, the vinyl was on offer at the time and I wanted some just to try out before committing to buying a roll. Maybe this vinyl was cheap for a reason.... I have received a search from MDP for their vinyl and will purchase a metre or 2 just to try out and see if this causes me any issues.
  3. #23
    Member
    Join Date
    Sep 2016
    Posts
    167
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok, I've been threatening to do it but i will be trying this out tonight. I need to press some vinyl on a tshirt for my kids for red nose day. Hopefully i can get it sorted.
  4. #24
    Member
    Join Date
    Sep 2016
    Posts
    167
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I used the settings that Scotty44 recommended and it worked perfectly. I realised that i was using 2 different types of vinyl. One of them felt like rubber which was difficult to cut however it appears to be working now & I managed to create 3 t shirts for my kids for red nose day without any vinyl wastage. I realised i was doing things wrong by completely cutting the vinyl out of the sheet. Does anyone use th clear transfer tape to line up their designs?
  5. #25
    Member
    Join Date
    Mar 2015
    Location
    Barnoldswick
    Posts
    39
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I love my Cameo 2. Mostly use 1 or 2 blade, occasionally up to 5. Never 9 or 10!
    Initially had an issue with tearing vinyl but solved by setting the Overcut Settings at the bottom of the Cut Settings panel to 0.2 or 0.3 (Start and End)
    Also, the Thickness setting apparently doesn't refer to the physical thickness of the material but to the density. The higher the setting the more push (or force) the blade has. You only need a low (about 5) setting for vinyl although each brand is different. Glitter vinyl needs more, say 15. A typical HTV setting for me would be:
    Blade 2
    Speed 7
    Thickness 5
    NO double cut!
    Line Segment Overcut On
    Start Ext 0.2
    End Ext 0.2
Posting Permissions
  • You may not post replies
  • You may not edit your posts
