User Tag List
Similar Threads
  1. Photoshop printing white background problem.
    By Mossy88 in forum Printing Problems/Issues
    Last Post: 19-06-2015, 09:48 AM
  2. Problem with colour on photoshop elements 12
    By Simong12 in forum Printing Problems/Issues
    Last Post: 11-01-2015, 08:09 PM
  3. Problem with colour on photoshop elements 12
    By Simong12 in forum Printers
    Last Post: 11-01-2015, 07:01 PM
  4. photoshop problem
    By scottmurray89 in forum General Dye-Sub Chit Chat
    Last Post: 25-02-2013, 08:04 PM
  5. Problem with photoshop elements?
    By AdamB in forum Printing Problems/Issues
    Last Post: 15-04-2011, 11:58 AM
Results 1 to 8 of 8
  1. #1
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Flipping problem in Photoshop ...
    I came across a small problem when producing mug wraps with drop shadows in Photoshop. My printer driver (Ricoh SG3110DN) doesn't have a Flip Image setting so I have to do this in Photoshop.
    The problem.
    My design had elements with Drop Shadow Effects, with the shadows falling to the bottom-right. However, when I reversed (horizontally flipped) the image for printing, the shadows didn't flip. It appears that Photoshop will only flip the image layer and not the effects attached to it.
    The solution.
    The best solution I found was to right-click all the layers with Drop Shadow Effects and convert them into Smart Objects. Flipping the Smart Objects also flipped the shadows.
    Here's a quick view of the technique ...
    BEFORE FLIPPING
    Both boxes are on Normal layers, with the same Drop Shadow applied.
    AFTER FLIPPING
    The top box has been converted to a Smart Object before flipping and the shadow flips with it, unlike the bottom box which is still a Normal layer.
    Basic stuff, I know, but not everyone is comfortable with Photoshop so I hope this is of use to anyone struggling with the same problem.
    Attached Images Attached Images
  2. #2
    Premium Member UK Printed Mugs's Avatar
    Join Date
    Aug 2014
    Location
    Poole, Dorset
    Posts
    2,110
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Hi webtrekker. Couple of alternatives which may be quicker:
    1. The flipping when printing in Photoshop is part of Photoshop functionality rather than the driver (although it can be part of the driver). When you head to "Print..." then select "Function > Emulsion down" which should do the trick
    2. After artwork is complete highlight everything (ctrl-a) and then copy what you see using ctrl-shift-c into a new document which will turn it into one layer. You can then flip horizontal and print.
    Maybe slightly quicker and easier.
  3. The Following User Says Thank You to UK Printed Mugs For This Useful Post:
    webtrekker (14-03-2017)
  4. #3
    Premium Member
    Join Date
    Jun 2014
    Location
    Bridgnorth
    Posts
    314
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Select top layer
    CTRL + SHIFT + ALT + E creates a composite (all visible layers) layer at the top of your stack.
    Edit, Transform, Flip Horizontal
    This sequence can be turned into an action to save time.
    However !
    The new layer will not respond to any further editing on the layers below, not a problem but worth remembering to save a lot of head scratching. If you make changes just delete the composite and create another.
  5. The Following 2 Users Say Thank You to wayupnorth For This Useful Post:
    knightweb (14-03-2017), webtrekker (14-03-2017)
  6. #4
    Member
    Join Date
    Jan 2015
    Location
    Leicester
    Posts
    91
    Downloads
    7
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Thanks wayupnorth, that's a good tip
  7. #5
    Member
    Join Date
    Mar 2015
    Location
    Barnoldswick
    Posts
    39
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I always do it the way UK Printed Mugs says in point no. 1. That way you are working the right way round all the time in PS so you can easily spot if something moves, and you aren't messing around with your artwork. The Emulsion Down feature in the Print dialogue box shows the mirrored image and how it sits on the page. When you've finished printing and go back to you file, nothing has been altered and any amends or future changes will be easy to do. I can't see any reason why you would want to do it another way. It's quick, easy and non-destructive. Or have I missed the point?
  8. #6
    Member
    Join Date
    May 2015
    Location
    United Kingdom
    Posts
    84
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Don't you just flatten the image then print?
  9. #7
    Member
    Join Date
    Mar 2015
    Location
    Barnoldswick
    Posts
    39
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Why do you need to flatten? It's one extra step that I don't seem to need - the print seems to come out the same. Just print the whole file in reverse using the print dialogue box.
  10. #8
    Member
    Join Date
    May 2015
    Location
    United Kingdom
    Posts
    84
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I didn't say you had to flatten it-i was just asking, anyway it's far less time consuming than the other solution that you agreed to.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
