User Tag List
Similar Threads
  1. Replies: 21
    Last Post: 22-05-2016, 02:47 PM
  2. Ricoh Printer Problem - any advice before i throw it out the window?
    By Judebill in forum Printing Problems/Issues
    Last Post: 30-06-2014, 03:09 PM
  3. Window Sun Screens
    By dazzul in forum Sourcing New Items
    Last Post: 15-03-2014, 04:34 PM
  4. Advice Needed Before I throw a BIG strop.
    By jennywren in forum Take a Break
    Last Post: 22-01-2013, 05:01 PM
  5. Replies: 35
    Last Post: 25-11-2011, 08:03 AM
Results 1 to 8 of 8
  1. #1
    Member
    Join Date
    Jan 2017
    Location
    Dublin
    Posts
    64
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Help me not throw this cap press out a high window.
    Bought it from ebay, I couldn't justify a huge outlay for a cap press so got a chinese one, now the shape of the platten and base are both way off any blank baseball or snapback caps I've pressed.
    It took me nearly 200 caps to do a 100 order.
    I'm close to launching this POS. Anyone recommend some DIY workarounds or modifications? I assume someone has been in this position before.
  2. #2
    Member
    Join Date
    Oct 2015
    Location
    Shropshire
    Posts
    548
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I tried my cap press once. That was it. Never again. Same chinese toss. Was part of a 5 in 1 i bought for the flat press and latte wrap.
  3. #3
    Member
    Join Date
    Mar 2015
    Location
    Oxfordshire
    Posts
    532
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What was wasted on caps would have gone toward a better one so take it as experience and look to replace it. I have an Adkins beta cap press and that works well. Ylu can find them secondhand where prices aren't so bad or buy new.
  4. #4
    Senior Member
    Join Date
    Jan 2012
    Location
    Germany-NRW
    Posts
    1,281
    Downloads
    2
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Know the problem too. The platten is the wrong shape and mine was not a cheap chinese one either.
    Got around the problem by laying a folded up t-shirt on the platten , making sure it was fatter in the middle so it raised the middle of the cap up and makes the platten the same shape as the cap. Now it works most times until another shaped cap comes along, usually a Rapper Cap, and the t-shirt has to be "re-moulded".
  5. #5
    Senior Member
    Join Date
    Sep 2009
    Location
    south
    Posts
    1,550
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had a cheap cap press, which gave me a few problems to get the cap to print at the right place I used tailors chalk to mark the middle and used bulldog paper clips the strong one to hold the cap in place. Not sure if that helps you
  6. #6
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Reading the above posts, I think I would steer clear of printing caps!
    When you are in business and taking on large orders you really need to have methods and machinery in place which is 100% reliable.
  7. #7
    Senior Member
    Join Date
    Sep 2009
    Location
    south
    Posts
    1,550
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by webtrekker View Post
    Once I discovered its quirk doing hats became easy. Even with the best equipment you still have a learning curve, It just take a bit longer with the cheaper presses
  8. #8
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Quote Originally Posted by jennywren View Post
    I'm glad you found a work-around jennywren. To scrap nearly 100 caps on an order, as stated by the OP, would certainly put me off for life!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
