Hi Guys,
I finally got my 1351 setup and seems to be working fine on a 7 day tester of signcut. Now im very very very new to this so be warned BUT im using an brand new a3 cutting mat to put my paper on to cut a stencil out on and it fires to the plotter great, starts to cut great then about half way through while moving backwards and forwards the mat seems to swerve off line? Heres what I have adjusted
speed
pressure/weight
blade offset
moved the pinch rollers in and out but kept them in the end about 25ml from each side (they are on the roller not in the gaps)
I have adjusted the pinch roller springs got them all level
I have tried to use the pinch rollers lever down/up on either side
set a setting in the software so there is less movement up and down the sheet when cutting
and a few other things that ive forgotten
But seems I cant get it right? Now im guessing that this is a basic setup bit ive not got yet so any help would be fantastic!!
Cheers all
Keys
