I should also mention that you can stick pens, pencils and even Sharpie markers into a Silver Bullet (and possibly other cutters) and use them to draw instead of cut. Useful for some purposes, especially when learning to use you cutter.
Well, I keep mentiong the Silver Bullet because that's the machine I have now and feel confident in talking about. I don't know about the Cameo 3, but I have a Cameo 2 which I've never used since getting the SB. In fact, the main reason I bought the SB in the first place was because I was very unhappy with the Cameo 2. The problems I had were things like the mat slipping under the rollers diue to the poor roller system, the absolutely abysmal optical system used for detecting registration marks, low cutting force, and poor blade life. I wasted tons of expensive media on this machine and decided I needed something much more robust, that would handle wider and thicker media with ease, do reliable, accurate, print and cuts EVERY time, and had blades up to the task.I was considering the cameo 3 as a basic starter, don't want to run before I can walk. I assume the cameo will be up to the task of cutting prints though stand to be corrected if wrong.
Just a thought is there much difference in the earlier cameo cutters over the cameo 3 ?
By all means get yourself a Cameo to try out as a cheap introduction. Others in here use them for vinyl cuts and seem to have no real problems. However, they are a bit limited on cutting width. The SB I have has an 18" cutting width and I've never need more, but they are available up to 24". Other machines, such as the Graphtec's can cut much wider material. Horses for courses really. If you want to cut vinyl directly from the roll then you need to find out what roll widths your supplier sells. Personally, I cut most vinyl on the cutting mat as I don't usually do large designs.
most vinyl is 500mm
I am considering the silhouette portrait cutting machine as a starter kit, I have a number of requests for hen/birthday T-shirts would this do the job ? Names, etc ?
I use a silhouette portrait and it will do what you want up to A4 size.
I brought s cameo 3 from magic touch. Like logo bear said. They after sales support is second to none. I've only started a couple months ago and those guys have been great. I love my cameo, I am going to be upgrading soon just because i feel the cameo is light use machine and I need something bigger like the ce600. But I will be keeping the cameo as its great. Plus the studio software that comes with it is all I needed to get started on plotter cuts. Very inexpensive way to learn but I highly recommend cameo 3
strandville (15-06-2017)
The cameo is, in my opinion, a hobby machine. I use Summas, just because the first machine I bought was a used Summa. It was probably 10 years old when I bought it and it gave me about 3 years of perfect work. That 1 used machine got me on my feet, it just kept going and going knocking out work. I think a 610 machine is about £1400, 3 year manufacturers warranty.
If you can afford it, get a top name machine, they WILL pay you back if you give them the work, some machines are £3-400 for a reason.
Out of my price range at the minute froggy but thanks for the advice, I just purchased the cameo given I have a number of requests for T-Shirts atm I am hopeful the cameo will get me going and I can invest further as I progress.The cameo is, in my opinion, a hobby machine. I use Summas, just because the first machine I bought was a used Summa. It was probably 10 years old when I bought it and it gave me about 3 years of perfect work. That 1 used machine got me on my feet, it just kept going and going knocking out work. I think a 610 machine is about £1400, 3 year manufacturers warranty.
