Hi all,
I had a couple white T shirts to sublimate today so went ahead, now usually I put greaseproof paper on top of everything but this time I forgot, I ended up with a slight yellow tinge. I pressed 20 florescent vests at weekend but even took the press outside to do this to avoid sheeting everything up (again using greaseproof paper on top (i always cover lower soft plate with a t shirt) I use an adkins swing press. I've been pressing a cotton white T at 180 for 50 secs a few times since trying to 'burn off' if you like any remaining florescent as i'm sure it cant be anything else, i mean i doubt it's burning it at 180 degrees and it doesnt look like scorching its more light yellow. If anyone does florescent what do they clean the press with after because this stuff seems to be lingering and i'm annoyed now for doing the vests! Might buy a separate press for it in future! Any helpful ideas or hints welcome.
