User Tag List
Similar Threads
  1. Image Sizes
    By De8n in forum General Dye-Sub Chit Chat
    Last Post: 19-10-2016, 10:49 AM
  2. Distorted image
    By R.Prints in forum Printing Problems/Issues
    Last Post: 29-04-2015, 12:45 PM
  3. can you use a image if its in another image
    By guarddog14 in forum Copyright and other legal matters
    Last Post: 03-12-2013, 12:00 AM
  4. Replies: 3
    Last Post: 05-02-2011, 04:02 PM
  5. can you use same image
    By scottc123 in forum Mug Presses & Ovens
    Last Post: 26-10-2010, 12:39 AM
Results 1 to 9 of 9
  1. #1
    Member
    Join Date
    Jun 2017
    Location
    belfast
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    cut printed image ?
    Hi, I would like to print images to transfer paper and cut out the image using the Silhouette plotter is this possible and is so how ? I have searched but can only find information on using the image in silhouette studio which isn't what I would like.
  2. #2
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Yes, it's possible, and yes, you need to cut from Silhouette Studio (or other compatible software). Why are you thinking you wouldn't like to do this? You need to vectorise the outline of your image before any software can cut it.
  3. #3
    Member
    Join Date
    Jun 2017
    Location
    belfast
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi webtracker, I have some intricate celtic images I want to transfer to cotton but would like to cut them out from the transfer paper after print I am just wondering if it is possible to print the image to transfer paper, then somehow get the silhouette to recognise the image on the paper and cut it, I'm likely asking too much of the silhouette lol
  4. #4
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    It's called 'Print & Cut' and you'll find lots of info on youtube. You need to print corner 'registration marks' along with your design to enable the Cameo to accurately determine where the outline should be cut around your image.
    However, I'm not sure if Silhouette Studio can handle printing using an ICC profile, which is what you'd need if printing with sublimation inks. I use Sure Cuts A Lot software for my cutter, which also can't use ICC's, but I output the print to a PDF file which I can then print directly from Photoshop, which DOES handle ICC profiles. I then cut that as if it had been printed from my cutting software.
    For cutting designs from a sheet without using registration marks then you need to look up the 'Hinge method.' Here's a video for the Cricut cutter explaining how to do that ...
  5. #5
    Member
    Join Date
    Jun 2017
    Location
    belfast
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Brilliant, many thanks.
  6. The Following User Says Thank You to strandville For This Useful Post:
    webtrekker (25-06-2017)
  7. #6
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,590
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    contour cut
    not print and cut :)
    <-- How To Print Stuff BLOG
  8. #7
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Quote Originally Posted by Paul View Post
    contour cut
    It's called 'print & cut' Paul amongst all crafters that use these machines, even though the printing isn't done on the same machine, like the BN-20. The job is still printed with reg marks and cut.
  9. #8
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,590
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    cut printed image ?
    So is called contour cut among crafters and printers i know. But i do understand why people call it print & cut even if its not correct.
  10. #9
    Member
    Join Date
    Jun 2017
    Location
    belfast
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    semantics regardless, thanks for the video, haven't tried it yet but will do shortly.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
