Looking for a copy of CorelDraw, not fussed re version. I just want
to re acquaint my self with Corel. New computer no CD drive so must
be on memory stick if poss..
THANKS IN ADVANCE..
THANKS IN ADVANCE..
it is available as a download, you could always buy the student version.
a portable cd drive is about £19 to buy i had to get one for my new laptop
[h=A dictionary is the only place where success comes before work]5[/h]Laura
Bwfcuk (27-07-2017)
I don't think the student version allows you to interface with Cutting Master?
Not sure but just a thought.
John
I have just downloaded the subscription version of Corel and that won't work with cutting master but the trial version of x7 does
Thanks guys, I may go down the student version. not doing any cutting just subli designs
to send to a friend who has a wide format subli set up. fancy doing large flags and banners..
just a thought are you allowed to use the student version for commercial use ??
no you are not BWFCUK its a student version, so you need to be a student to use it, are you at the university of life?
I've just bitten the bullet and upgraded to X8. Corel wanted £600 (They will knock 50% off this though) but I bought from the US for around £150, full commercial boxed version. I've always worked well with X4 but needed the cutting master to work directly.
Coreldraw X6 is not compatible with Windows 10 = very annoying!!
Hi Justin
can this just be brought from any U.S. Site? And is it like compatible etc? Just asking because that's an amazing saving and i really want to get onto Corel draw.
I'll send you over the eBay auction I bought it on. I think it was £153, plus taxes etc. it still came in under £200. There's a slight issue installing X8 that I am now aware of! It tells you to remove all previous versions but even once you have it still fails. It appears you have to remove Microsoft Visual C++ 2015, install X8 and then reinstall Visual....just in case anyone has this issue!
