Premium Membership available at just £10 per year.....Discounts with top Sublimation Suppliers!
Similar Threads
  1. Print CMYK test in margin of print (Photoshop)
    By pisquee in forum General Dye-Sub Chit Chat
    Last Post: 29-06-2014, 10:36 AM
  2. ties?
    By AdamB in forum General Dye-Sub Chit Chat
    Last Post: 27-03-2013, 01:09 AM
  3. Clip on ties
    By Dave271069 in forum Clothing
    Last Post: 19-02-2013, 08:17 PM
  4. ties
    By jennywren in forum General Dye-Sub Chit Chat
    Last Post: 31-03-2011, 10:36 PM
Results 1 to 5 of 5
  1. #1
    Premium Member logobear's Avatar
    Join Date
    Feb 2010
    Location
    Newcastle upon tyne. UK
    Posts
    1,346
    Downloads
    0
    Uploads
    0
    How to print ties ?
    I have a request to supply & print 20 black ties with a block of print to occupy the bottom point in a wedge shape about 13cm up. multi colour print
    We will use Premier PR700 poliester ties.
    I could use print & cut, or magic Touch WOW, or hand trimmed OBM laser print.
    i have no problem sizing & shaping artwork, . but how to apply?
    I want/need to avoid the 'pressure' mark you get where the back seam stitches create a fat bit and show through.
    I don't want to unsew & re sew after printing.
    perhaps I use a teflon cusion under?
    Any suggestions / tips ?
    Many thanks. Phil
    1 Hour T-shirt printing in Newcastle upon Tyne
    Logobear tshirt print and embroidery. 74 Clayton Street. Newcastle. NE1 5PG
  2. #2
    Premium Member
    Join Date
    Nov 2009
    Location
    Newcastle upon Tyne
    Posts
    2,953
    Downloads
    0
    Uploads
    0
    I know this is slightly different, but when we used to screen print on to ties, we used to slide the tie on to a (tie shaped) jig, this got rid of the ridge effect. When ordering in the ties, we had to make sure you could actually slide the jig inside the tie. A thin bit of metal or mdf would do the trick!
  3. #3
    Join Date
    Feb 2010
    Location
    Posts
    1,346
    Downloads
    0
    Uploads
    0
    Yes, we have made an mdf board to shove up em!
    understand i can use wow at 110c and obm at 120c so should avoid shiney look.
    OBM at lower pressure so perhaps best?
  4. #4
    Premium Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    961
    Downloads
    0
    Uploads
    0
    Quote Originally Posted by logobear View Post
    Ooh! Hope they're not German ties logo, they don't like it up 'em!
    On a more positive note, seeing as most folk never wash a tie, I suppose that leaves a lot of scope for transfer methods.
  5. #5
    Senior Member
    Join Date
    Sep 2009
    Location
    south
    Posts
    1,581
    Downloads
    0
    Uploads
    0
    I use WOW on ties with no trouble if that any help
Posting Permissions
  • You may not post replies
  • You may not edit your posts
