User Tag List
Similar Threads
  1. Is this problem down to the paper im using?
    By adamctid in forum 3D Sublimation
    Last Post: 13-06-2015, 10:06 AM
  2. Insert paper for full bleed t-shirts
    By DigitalTed in forum Clothing
    Last Post: 04-12-2012, 07:20 PM
  3. Sublimation problem with Trupix paper
    By sandid in forum Printing Problems/Issues
    Last Post: 23-12-2011, 02:36 PM
  4. Problem with ink blotching/bleeding through paper
    By Bass3rd in forum Printing Problems/Issues
    Last Post: 08-01-2010, 05:43 PM
  5. Paper problem
    By swimwivsquid in forum Printing Problems/Issues
    Last Post: 04-01-2010, 10:24 PM
Results 1 to 9 of 9
  1. #1
    Senior Member logobear's Avatar
    Join Date
    Feb 2010
    Location
    Newcastle upon tyne. UK
    Posts
    1,669
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    sub ink bleed through paper problem
    We have noticed that if we sub a mug with wide coverage, then do one with a much smaller print area then some of the previous image is transfereing onto the next mug where it is not wrapped in paper.
    We are using TMT SubMagic paper which we think gives weaker results that our previous (unwatermarked) product.
    We use a DT 180, and have just changed the element.
    Do all papers bleed through and impregnate the heat element, possibly marking future mugs?
    It might have been happening for a while and we havn't noticed, or it could be a new problem?
    Any ideas??
    Phil
  2. #2
    Senior Member
    Join Date
    Nov 2009
    Location
    Newcastle upon Tyne
    Posts
    2,937
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You could use a second sheet of paper wrapped around to protect the mug from any ink left on the blanket. Must say i haven't had this problem though - I'm using xpres paper, don't know if it makes a difference.
  3. #3
    Senior Member
    Join Date
    Dec 2009
    Posts
    2,050
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can't you just cut your transfer the same size with the print positioned on it where required? I don't see the benefit in cutting the transfer smaller than the largest wrap used as you will often get a certain degree of ink transfer.
  4. #4
    Senior Member purpledragon's Avatar
    Join Date
    Nov 2009
    Location
    Pembrokeshire
    Posts
    1,521
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    sounds like cheap thin paper to me
  5. #5
    Member
    Join Date
    Sep 2011
    Location
    Galway
    Posts
    248
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    when I heat my mug press up with the scrap mug in it bits of old designs have started to appear on this mug, just shadowy but you can see it . I'm using sublimation paper from coralgraph and ar Tanium inks. I thought perhaps I had the heat a little too high but happy with the mugs I'm making (although not done many)
  6. #6
    Senior Member smitch6's Avatar
    Join Date
    Jan 2011
    Location
    back in Suffolk at last
    Posts
    1,767
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    get some cheap greaseproof paper
    and wrap your mug in it
    it's cheap so disposable works a treat :)
  7. #7
    Senior Member
    Join Date
    Nov 2009
    Location
    Newcastle upon Tyne
    Posts
    2,937
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just used a new mug without print - wasting 1 mug is cheap compared to a new blanket.
  8. #8
    Member
    Join Date
    May 2011
    Location
    Norfolk
    Posts
    211
    Downloads
    0
    Uploads
    0
    Mentioned
    2 Post(s)
    Tagged
    1 Thread(s)
    I'm with Andrew on this one, and would suggest that whatever the print area of your design you cut the mug paper out at the same size - ie, top to bottom on the mug, and to the handle. As well as eliminating ink contamination from the heater band this will also enable you to use your PC or Mac to set the position of your design on the product for greater consistency.
    This is how we do them anyway. Laying out to pre-defined artwork templates dor each of the mug styles.
    Hope this helps.
    Alex.
  9. #9
    Senior Member
    Join Date
    Sep 2009
    Location
    south
    Posts
    1,550
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    we also cut and design the paper to fit the mug, it is so much quicker and easier. When your doing 200 to 300 mugs having the design in the same position looks far more professional. if for some reason I have not cut it right and it doesn't fit the mug I just use normal paper on top.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
