Just echo Martins response - whoever sells the ink should supply a profile, if your printer isn't supported, then, as smitch said, ask Paul to make you one.
Hi! yes. you need to print with profile. Is worth to ask your guy from inks if he got one!
<-- How To Print Stuff BLOG
On Ebay, so you've either bought someone's old/unwanted supported Sawgrass desktop sublimation ink, or rebottled large format ink from InkTec or Fuji (which obviously you haven't done as the adverts on Ebay make it quite clear that you should not use these inks in printers smaller than 42" wide.) If the former small format then there may be a profile of their you could use for a similar model printer, if the latter, then you will need to get a custom ICC made. Paul offers this service, and is very good, and his price is very reasonable.
Last edited by pisquee; 03-02-2012 at 11:43 PM. Reason: missing NOT as mentioned by BMSbelow
Just being pedantic, but it should read "the adverts on Ebay make it quite clear that you should not use these inks in printers smaller than 42" wide"
Woops. Fixed. That was honestly a mistake.
