User Tag List
Similar Threads
  1. 40 x 40 Swing away press
    By Bob700 in forum Heat Presses
    Last Post: 05-02-2015, 07:04 AM
  2. Just got a swing press
    By SilentAlf in forum Heat Presses
    Last Post: 08-09-2013, 06:04 PM
  3. Wanted A2 Swing away press
    By JMugs in forum Buy It, Sell it, Give it away!
    Last Post: 05-08-2013, 10:25 PM
  4. Swing or clam?
    By twinsgran in forum Heat Presses
    Last Post: 13-03-2013, 01:58 PM
  5. is it a swing away
    By bigj2552 in forum Heat Presses
    Last Post: 07-02-2012, 10:25 AM
Results 1 to 5 of 5
Thread: swing away
  1. #1
    Senior Member
    Join Date
    Feb 2012
    Location
    South Ayrshire
    Posts
    2,203
    Downloads
    3
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    swing away
    the one bought from BMS last yr - great little press.
    but.........
    when i,m doing a large run of cases, i keep having to switch it off by the main switch at the side then back on again for the next run.
    there is a little button next to the main on/off switch, but it never worked from day one, and i always used the on/off switch. - Thats fine for the odd case here n there, but its getting slightly busier and i was wondering how to leave the press ON without the bloody thing beep beep beeping all the time till i,m ready with next lot
    what was the little button for, it for can anyone tell me ?
  2. #2
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,591
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    small red button is to start your countdown :) so if is bipping all the time i take it as is pressed for good :)
    you can ask BMS to fix it for you or you can disconnect the little speaker inside.
    <-- How To Print Stuff BLOG
  3. #3
    Senior Member
    Join Date
    Feb 2012
    Location
    South Ayrshire
    Posts
    2,203
    Downloads
    3
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Paul View Post
    hi paul
    its a small black button next to main on/off switch and its knackered from day one ! - just wondered what it was for
  4. #4
    Senior Member bms's Avatar
    Join Date
    Oct 2009
    Location
    Dorset
    Posts
    4,079
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by bigj2552 View Post
    hi paul
    The black button holds a fuse inside. It's not "knackered" if the press is working fine. It's a safety mechanism and in normal use would not need to be touched.
  5. #5
    Senior Member
    Join Date
    Feb 2012
    Location
    South Ayrshire
    Posts
    2,203
    Downloads
    3
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by bms View Post
    cheers martin - wee press working great indeed just always wondered what that was for.
    so what the press's you can get that you press a button and it leaves press on while you change products to be pressed, as in without switching off the mains switch on the press every time you do a run of cases ect ? - like a thermostat on it or something - is there such a thing
Posting Permissions
  • You may not post replies
  • You may not edit your posts
