User Tag List
Similar Threads
  1. DF30 Swing Away Press
    By Maggie in forum Heat Presses
    Last Post: 27-02-2015, 08:36 AM
  2. 40 x 40 Swing away press
    By Bob700 in forum Heat Presses
    Last Post: 05-02-2015, 07:04 AM
  3. Wanted A2 Swing away press
    By JMugs in forum Buy It, Sell it, Give it away!
    Last Post: 05-08-2013, 10:25 PM
  4. Swing Press Question
    By Kahboose in forum Heat Presses
    Last Post: 11-07-2012, 09:13 AM
  5. clamshell press vs. Swing away
    By Paul in forum Heat Presses
    Last Post: 30-06-2011, 06:12 PM
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    Member Mossy88's Avatar
    Join Date
    Sep 2012
    Location
    Portsmouth
    Posts
    92
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Jeff View Post
    Hmm, sounds like cheap quality...that can really be a pain in the a**, having to check the bolts everytime you use it...
    It was a cheapy one, it was a few months before it come apart. i dont no if it was something i did.
    Mike
  2. #12
    Member
    Join Date
    Apr 2013
    Location
    St. Albans
    Posts
    290
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yup mine was a cheapy too from Ebay, get what you pay for at the end of the day but its doing the job it needs to for now and the way I see it is if it lasts a year then it has more than paid for itself..
  3. #13
    Junior Member Jeff's Avatar
    Join Date
    Apr 2013
    Location
    lincoln
    Posts
    9
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yup, if you plan to use it just now and then or just for one specific purpose, then screw the storage life. Otherwise, I would definitely recommend better quality.
    Hey young world
  4. #14
    Member SilentAlf's Avatar
    Join Date
    Sep 2012
    Location
    St Leonards On Sea
    Posts
    69
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you all for your advice.
    Does anyone know the best template size to use for coasters 95mm?
  5. #15
    Senior Member bms's Avatar
    Join Date
    Oct 2009
    Location
    Dorset
    Posts
    4,079
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by SilentAlf View Post
    ...errr 95mm square! :)
    Always make your templates a couple of mm larger so you can position the coaster easily, do around 97mm would be fine.
  6. #16
    Join Date
    Sep 2012
    Location
    St Leonards On Sea
    Posts
    69
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When printing onto t-shirts using the swing press what fabric does the T-shirt have to be? and where can you buy them from?
  7. #17
    Member
    Join Date
    Apr 2013
    Location
    St. Albans
    Posts
    290
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can press pretty much any fabric with the press mate, I mainly use cotton or a poly/cotton mix cause I mainly do vinyl but you can also use polyester for sublimation and even materials like spandex can be pressed. Hope this helps :)
  8. #18
    Join Date
    Sep 2012
    Location
    St Leonards On Sea
    Posts
    69
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That does help thank you. I think i need polyester as i will be using sublimation. do you know a supplier/wholsaler for polyester clothing?
  9. #19
    Member
    Join Date
    Apr 2013
    Location
    St. Albans
    Posts
    290
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I normally use ralawise but there are also Pencarrie, BTC Activewear and I'm sure there are a couple of guys on here that sell Polyester tees :)
  10. #20
    Join Date
    Sep 2012
    Location
    St Leonards On Sea
    Posts
    69
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi All,
    I completed my first dye subli on a t-shirts today and it came out great!!
    Only question i have though is that the outline of the A4 sized paper showed on the t-shirt!
    I tried to iron it out but it was still there. Would this happen if the pressure on the heat press was high?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
