User Tag List
Similar Threads
  1. DF30 Swing Away Press
    By Maggie in forum Heat Presses
    Last Post: 27-02-2015, 08:36 AM
  2. 40 x 40 Swing away press
    By Bob700 in forum Heat Presses
    Last Post: 05-02-2015, 07:04 AM
  3. Wanted A2 Swing away press
    By JMugs in forum Buy It, Sell it, Give it away!
    Last Post: 05-08-2013, 10:25 PM
  4. Swing Press Question
    By Kahboose in forum Heat Presses
    Last Post: 11-07-2012, 09:13 AM
  5. clamshell press vs. Swing away
    By Paul in forum Heat Presses
    Last Post: 30-06-2011, 06:12 PM
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Member
    Join Date
    May 2013
    Location
    Midlands
    Posts
    32
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by SilentAlf View Post
    Only question i have though is that the outline of the A4 sized paper showed on the t-shirt!
    I tried to iron it out but it was still there. Would this happen if the pressure on the heat press was high?
    Are you talking about the outline of the A4 paper or the outline of the press platen itself? The latter is quite normal and will normally disappear when the tee is washed for the first time. The edge of the paper itself may also leave a slight impression but that too will disappear. Getting the pressure right is something that will only come with experience. If you have insufficient pressure the image will not transfer fully. Have excessive pressure and you may find fleks of colour outisde the main image area.
  2. #22
    Supplier subli's Avatar
    Join Date
    Jul 2011
    Location
    South Manchester
    Posts
    55
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi All,
    I completed my first dye subli on a t-shirts today and it came out great!!
    Giving the Tshirt a quick pre-press (light pressure, 4-5 secs) to remove excess moisture can help to reduce the pressure marks a bit.
    Meshtex Ltd -
    - 01625 876949. Wholesale Supplier of Dye Sublimation Equipment, Blanks & Consumables.
  3. #23
    Premium Member
    Join Date
    Nov 2011
    Location
    Bishop Auckland, County Durham
    Posts
    4,280
    Downloads
    0
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    3 Thread(s)
    ripping the edges off the paper also gives it less of a sharp edge, which can also help in not having such pronounced paper mark on the t-shirt
  4. #24
    Junior Member
    Join Date
    Aug 2013
    Location
    Batley
    Posts
    24
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have you tried putting a flat then a spring washer under the wing nut?
    Geoff
Posting Permissions
  • You may not post replies
  • You may not edit your posts
