User Tag List
Similar Threads
  1. Teflon sheet
    By FBW in forum Heat Presses
    Last Post: 29-01-2015, 03:04 PM
  2. cooper coloured teflon
    By bigj2552 in forum Take a Break
    Last Post: 15-05-2014, 10:57 AM
  3. Marks from Teflon/PTFE sheets on print
    By Photomouse in forum General Dye-Sub Chit Chat
    Last Post: 13-03-2014, 11:57 PM
  4. teflon sheet
    By Paul in forum General Dye-Sub Chit Chat
    Last Post: 23-12-2012, 05:11 PM
  5. silicon/teflon sheet
    By Craig in forum General Dye-Sub Chit Chat
    Last Post: 13-08-2012, 05:54 PM
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Member
    Join Date
    Jul 2010
    Location
    Milton Keynes
    Posts
    26
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: Do I need teflon sheets?
    So, can I get this right, you place a sheet of greaseproof paper on the teflon bottom plate, then the t shirt on top, followed by the transfer paper dye sub ink print then a further greaseproof sheet before pressing down the top plate for the heat transfer? Is that correct, as I dont want to burn my mum's house down at my first attempt at t shirt printing. Try explaining that one to the fire investigation officer lol. :lol:
    Also, can I ask about temperatures, if using a dye sub suitable t shirt with an A4 size colour paper transfer, what temp should I use and for how long? The G3838 heat press I bought is okay but the manual is in pidgeon German so pretty hopeless and no explanation of temps etc. Or, will the transfer paper I buy have an instruction sheet and temp guidances?
    Remember: Every Day is a Good Day, some Days Just Come with Clouds!
  2. #12
    Senior Member Ian M's Avatar
    Join Date
    Jun 2010
    Location
    Bradford
    Posts
    1,560
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Steve,
    I just put the T-shirt onto the bottom plate silicon rubber & I just use Asda silicon grease proof paper on top of the transfer. This works fine for me as I don't do too many T-shirts at the moment.
    I press at 190 degrees C for 50 seconds.
    The temp & the time are a bit trial & error to begin with but one big tip is to write down your settings once you have them.
    When I first started I bought a load of cheap microfibre dusters to practice on which worked fine.
    Xpres used to have a chart on their website which you could download but, seems to have gone now.
    Good luck.
    Ian
  3. #13
    Member
    Join Date
    Jul 2010
    Location
    Milton Keynes
    Posts
    26
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi Ian, many thanks for the tips! The more tips and advice I can get the better and I like the idea of practising on the microfibre dusters, saves a fortune on damaged t shirts. Cheers!
  4. #14
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,257
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    Quote Originally Posted by Ian M
    I should have a copy of this that I can upload, will sort out.
  5. #15
    Senior Member
    Join Date
    Mar 2010
    Location
    Glasgow
    Posts
    1,413
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Steve
    If you get a dmamged tshirt, just keep it for practicing on, that's what I do :)
    I've got a few tshirts upstairs, in differnet colours, that have subli/vinyl and transfer papers on :lol:
Posting Permissions
  • You may not post replies
  • You may not edit your posts
