you seem (quite rightly too ) quite centred on quality ie you want a press that will have an even spread of heat etc . you shouldnt have any issues with an adkins or stahls for example but a press for £109 maybe a simple matter, to put it in a way that you can relate to , you are a photographer if i was asking you for advice on what camera to buy would you recomend a cheap vivitar or would you recommend a nikon ? im pretty sure you would advise the latter . the same applies to presses you get what you pay for £109 is dirt cheap and i doubt the seller is simply the generous sort so it must be quite a bit cheaper to them quality always shines through i believe both adkins and stahls have small presses try speaking to target transfers or xpres
