User Tag List
Similar Threads
  1. Novachrome Mug Press test against Xpres Mug press
    By Zipdorf in forum Mug Presses & Ovens
    Last Post: 18-01-2013, 08:07 PM
  2. Ricoh 3300, flat press, mug press complete setup
    By Titan Print Studio in forum Buy It, Sell it, Give it away!
    Last Post: 14-12-2012, 11:06 AM
  3. For Sale SENKO CAP PRESS plus plate press and newstar 40 vinyl plotter cutter
    By letsgo in forum Buy It, Sell it, Give it away!
    Last Post: 13-10-2012, 11:07 AM
  4. Wanted plate press - latte press- vinyl cutter wanted
    By Mattie in forum Buy It, Sell it, Give it away!
    Last Post: 30-12-2011, 06:01 PM
Results 1 to 8 of 8
  1. #1
    Member
    Join Date
    Aug 2014
    Location
    Lancashire
    Posts
    34
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The best mug press?
    HI Guys- First post here!
    We're sublimation printers based in Lancs. We run a tidy fleet of 6 Adkins dual mug press (s) and 2 Chinese mug presses. The Adkins are great machines and we love them. Hassle free and the heat is nice and even around the mug.
    We want a heat press which reduces the gap between the handle and design. Currently its about 0.8 inches... Pretty big and can be annoying when people want to colour the full mug. I've seen some other mugs in the market and the gap between design and handle is extremely close at about 1 CM. Which press and has anyone used / seen something like this before.
    Any questions please let me know!
    PS: We use Xpres 5013 mugs
    Tom
  2. #2
    Member
    Join Date
    Aug 2014
    Location
    Lancashire
    Posts
    34
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Oh. We can do closer than 0.8 Inch BUT can cause some problems on larger runs when the element runs out near the edge of the press.
  3. #3
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,257
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    I use the Adkins single head presses (would love to try the dual head) and obviously have the same issue. I don't tend to find it a problem but would like to get closer if possible. My press closes right up to the handle so in theory it looks like I could get closer...but can't. I agree, full wrap can look odd and so I avoid full putting a small gap top and bottom to complement the gaps adjacent the handle.
    We've discussed printing under the handle recently on here and a couple of ideas were mentioned. I bought a sublimation mug whilst on holiday (which is usually a no no buying someone elses!) but wanted to look at it as it was printed right under, it does look good.
  4. #4
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,257
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    Quote Originally Posted by cleverprintinguk View Post
    So is the problem that the heat doesn't reach the outer edge?
  5. #5
    Member
    Join Date
    Aug 2014
    Location
    Lancashire
    Posts
    34
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The heat press is fantastic for the rim to the bottom of the mug and makes printing top to bottom a breeze!
    Yep ours closed right to the handle. but sadly struggles to get anywhere near with the heat. Called Adkins and they say the heat press can't get any closer than what we currently do :( It's a little disappointing!
    I think maybe a mug oven would make getting closer to the handle alot easier?
    Cheers! :D
  6. #6
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,257
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    I was never happy with the mug ovens tbh but you may get a little closer.
  7. #7
    Premium Member UK Printed Mugs's Avatar
    Join Date
    Aug 2014
    Location
    Poole, Dorset
    Posts
    2,113
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Hi. Although I am new to mug sublimation I must say that I have tried three ovens and conclusion was - stick with a mug press unless you use the mini vacuum from say BMS. Mini vacuum is very small but fits four mugs and kept perfect temperature. I also tried the new andrewjames (hinged) halogen oven and counter top convection oven but both had unreliable temperature controls and mug heating was so inconsistent that I threw more mugs away than selling. So although in theory you could potentially get closer to handle, the chances are the sublimation may not be consistent so financially may lose you money in time and stock.
  8. #8
    Member
    Join Date
    Aug 2014
    Location
    Lancashire
    Posts
    34
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    We've never tried a mug over but time and time again, more bad feedback is coming. I think we'll stick to he mug press and hopefully find a solution soon!
    Cheers all
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
