Installing Ricoh printer software on a Mac - help!!
So, I've bought the BMS starter kit with Ricoh SG3110.
I have a MAC so I have been following the instructions relevant to MACs: https://www.sawgrassink.com/Portal/T...loads-(1).aspx.
I am not having much luck installing the software onto my macbook.
My Mac is OS X El Captian Version 10.11.16.
I downloaded the Ricoh driver without issue, however, when I try to install Java (which is part of the process) I get this message:
"Java for OS X 2014-001 can't be installed on this disk. A newer version of this package is already installed."
I thought this was a GOOD thing - and whatever newer version that is already installed would work.
But when I try to continue on to the next step - installing the SubliJet-R SG3110/SG7100 MacProfile - it says "To open "SGReg" you need to install the legacy Java SE 6 runtime."
Bit of a nightmare. Would be grateful if you anyone could help.
