Originally Posted by
WorthDoingRight
Well, being short of money and always willing to go the non traditional route I took the plunge and went for a Brother A3 all-in-one for under £100, a set of refillable cartridges for £20 and filled those with bulk ink. After getting the 'out of the box' print settings adjusted with help from bigj2552 I had more than acceptable results. Profiling will give you extra comfort when printing so well worth arranging once you have worked out all the basic settings. It is worth remembering however that profiling matches your current ink to your current sublimation paper and if you change either you may require a new profile hence best to work out what combination works for you best then get that combo profiled.
The brother printer has the added bonuses imho of being able to print up to A3 size, has a built in A4 scanner and seems to work perfectly over my wireless network so can be hidden in the corner :smile:
