Though of course you could test this by checking for a voltage across the input of the relay when the press is supposed to be heating. They are usually DC and less than 50V, but prudence when testing is always good!
Another possibility is that the voltage that should be supplied to the switching contacts of the temperature controller is missing, in which case there won't be a signal to trigger the SSR...
