Yes, Both controllers are exactly same model, input output voltage etc !!!
just as an aside, if I put a low voltage thru the SSR then it operates and the press will indeed heat up, albeit with no temp control - but it does work.
As you said in an earlier post, the problem is that the controller is not sending anything to the SSR !
hope to be in early today - to resume my investigations ;-)
Decca
