Originally Posted by
JSR
Do you get the larger ones from a different manufacturer to the smaller ones, then?
The chopping board itself seems to be okay, it's just the ink-receptive coating on the back that seems to be on backwards or something for the 265mm ones. When you finish pressing them, there's more print on the underneath than what you can see through the glass - unlike the Listawood ones which are vibrant and fully-saturated when seen through the glass, but almost white on the underside.
There's certainly a different coating involved. There must be.
