Can I ask how long you pre heated the mugs for?
Printable View
even in a press I have to preheat especially on full prints
you need to preheat long enought that the thick base on the mug is heated through... at these temps it's too cold to sub so can't over do it
in my press I preheat at 100 degrees for about 3 minutes.. long enough that when I touch the base in the centre it's no longer cold
Sent from my SM-G998B using Tapatalk
I have to be honest, in the years that I’ve printed mugs (and we do hundreds a day), we’ve never pre heated a mug, ever.
That being said, I wouldn’t discount it’s benefits and I will definitely give it a try. We have 5 ovens at present so plenty to play with.
We have also just had a quantity of mug presses delivered to help over Christmas and I’ve bought a hot plate to pre heat the bottoms of the mugs.
They were in for as long as the others were cooking, so the six mugs came out on a tray and were wrapped, then put in the main oven to cook. Leaving them on the tray while I wrapped them kept the warmth in them. So pop the six in the main oven, put a fresh six on the tray, pop in the other oven to warm.
Janners
I have just dug out my small oven after a lot of searching I found a wrap. 1 mug 15 minutes. The dial shows 175, the thermometer inside shows 205, I doubt either is accurate. Rhino coated mug prints a treat. Just ordered some new wraps.
Reason...?
If there is a problem with my presses in the run up to Christmas, then it's back to the oven!
This thread prompted me, so thanks folks.
Janners
