User Tag List
Similar Threads
  1. Doming Media, Printing Problems
    By RoyLittle0 in forum Vinyl & Flock
    Last Post: 14-02-2014, 07:45 AM
  2. Doming
    By s31teg in forum Member to Member Offers/Requests
    Last Post: 18-07-2013, 12:25 AM
  3. Anyone on here do doming
    By socialgiraffe in forum General Dye-Sub Chit Chat
    Last Post: 19-06-2013, 01:06 PM
  4. Keyring Doming
    By mrs maggot in forum General Dye-Sub Chit Chat
    Last Post: 28-01-2010, 07:00 PM
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
  1. #21
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,591
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    Re: Doming - Anyone tried it?
    some good prices here if you want to give it a go :)
    http://www.mdpsupplies.co.uk/productcat ... ame=Doming Supplies&parentcat=28
    <-- How To Print Stuff BLOG
  2. #22
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,256
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    So this is based upon a single epoxy or is it 2 and needs mixing? Also, I assume that the mini blow torch is for setting the epoxy so no UV required?
  3. #23
    Senior Member Ian M's Avatar
    Join Date
    Jun 2010
    Location
    Bradford
    Posts
    1,560
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Justin,
    It is a 2 part acrylic & both parts are in the applicator so when you press it both parts mix as it comes out of just the one nozzle.
    The blow torch is usually used to get rid of the air bubbles that become trapped.
    I think you would still need the UV to set them.
    You could always do it like I do & use a small company that just do arylic doming. :D
    They have just done a large job for me & I have 100% mark up on it :D
    Ian
  4. #24
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,256
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    I'm guessing the UV is the expensive bit? I was asking about Crystal printing which also uses the UV source, maybe I could use the box for both?
  5. #25
    Join Date
    Jun 2010
    Location
    Bradford
    Posts
    1,560
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Justin,
    I don't think you need a UV lamp as the acrylic air dries as it has a catalyst mix in with it.
    Have a look at this link as I found it quite useful http://www.make-a-gift.co.uk/packages.htm
    Ian
  6. #26
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,591
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    air dry will take few hours to cure. with uv units few minutes :)
    but who said UV unit must be expensive??? you can but just uv bulb or any uv unit on market. dont need to be doming dedicated one ;) I will use my wife nile cure lamp :D
  7. #27
    Junior Member
    Join Date
    Mar 2010
    Posts
    23
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The biggest problem with doming is if your not UV curing you need a room with a humidity level of around 40%, otherwise you will be plagued with problems with bubbles, also the resin has a short shelf life, yes its relatively easy to do but unless you have the right enviroment for the resin to cure it can be very wasteful and expensive.
  8. #28
    Join Date
    Jun 2010
    Location
    Bradford
    Posts
    1,560
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks Paul & Jase.
    I'm learning more & more about doming now. I'd love to have a go at some time myself but, just think it might be a step too far just now.
    Ian
  9. #29
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,256
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    http://www.victory-imaging.co.uk/techni ... ctions.pdf
    Just found this start up kit which seems to be a very good price, would love to have a go. All looks a little time consuming for the double sided keyrings I do but worth the effort. I wonder how practical it would be just doming 1 or 2 keyrings though?
  10. #30
    Junior Member
    Join Date
    Mar 2010
    Posts
    23
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not very practical because you would have to bin the rest of the resin cartridge if you only did 1 or 2 key rings so it would be expensive
Posting Permissions
  • You may not post replies
  • You may not edit your posts
