User Tag List
Similar Threads
  1. DF50 Heat Press, Rock Slate printing.
    By twinx05 in forum Heat Presses
    Last Post: 07-01-2015, 10:54 PM
  2. The Rock Slate Printing Problems!
    By funkey monkey in forum General Dye-Sub Chit Chat
    Last Post: 13-04-2014, 09:44 AM
  3. Photo Rock/Slate
    By MikeyMike in forum Printing Problems/Issues
    Last Post: 27-02-2014, 09:52 PM
  4. PINT GLASSES and Rock slate clocks?
    By madmagowan1 in forum Sourcing New Items
    Last Post: 27-12-2013, 08:32 PM
  5. Rock Slate
    By Blue-Belle-Larkhall in forum Sourcing New Items
    Last Post: 10-12-2013, 02:17 AM
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Junior Member
    Join Date
    Nov 2017
    Location
    welshpool
    Posts
    2
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi ive been reading all comments on slate its something I want to do i have good success with coaster size 480 sec 190oc med pressure then i go a size up with same settings and I have a small issue when you look at the slate it looks good but when you tilt the slate under the light you can see small spots bits that seem dull like the gloss finish dull it's like the print did not transfer .
    as i use bigger sizes do i need to increase the time? ie added the slate below although you cant see the issue on the photo,the sun rays are on the photo
    Attached Images Attached Images
  2. #12
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,369
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by JMugs View Post
    I use chip shop paper from ebay, cheap and large so can be torn to any size, then used as packaging when scrunched up or squashed in the paper log maker.
    Old thread I know, but thanks for the paper log maker suggestion!
    Why use chip shop paper rather than cheap copy paper? It seems more expensive. I'm using cheap copy paper, then the teflon to protect the platen which never needs changing.
  3. #13
    Member
    Join Date
    Dec 2016
    Location
    Abergavenny
    Posts
    257
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I use cheap copy paper for anything up to A4 size but try getting cheap copy paper at A3 size. This is where cheap chip shop paper (aka newsprint offcuts) come in handy.
    Dirt cheap and comes in large enough sizes to deal with most print jobs :)
  4. #14
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,369
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by Customprintwales View Post
    2 sheets of A4! Every A size is double the size of the lower size.
  5. #15
    Junior Member
    Join Date
    Nov 2017
    Location
    welshpool
    Posts
    2
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    can anyone suggest what i can do with larger size slate that leaves a good clean print with no small bits that look like there is no gloss finish
  6. #16
    Member
    Join Date
    Jan 2018
    Location
    Worcester
    Posts
    79
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Used your method for rock slates and seems to work quite well compared with other methods I've tried, although colours are not coming out as vibrant as I would like compared with all the other items I've been printing. Just wondering should I perhaps saturate images when printing for slates?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
