I have a problem with my Epson 7890 which is only 11 months old, hardly been used - in fact I didn't use it for a month which has caused the cyan printhead to be partially blocked. When running a nozzle check about quarter of lines were visible if that.
After numerous power cleanings and trying other cleaning solutions I found on youtube there was little improvement.
As I decided to upgrade to a Sawgrass printer and had given up the warranty. I decided to dismantle the printer and see if I could fix it myself - so with the aid of youtube I eventually successfully got to the printhead.
I then cleaned it by flushing cleaner through each colour until clear of any ink and put it back together.
I did a power clean and ran a nozzle check - All the colours were fine again except the cyan - which had improved but this time only half the lines missing. I did run a test print of 100% cyan which looked fine.
Does anyone know what is wrong? - is it the printhead, could it be the Sawgrass ink? Is it fixable or worth anything for spares? Any advise welcome - it seems mad to right off the machine for one colour not printing 100%
