User Tag List
Similar Threads
  1. Need help with LIYU VINYL CUTTER PLOTTER SC631E
    By Miss D in forum Vinyl Cutters
    Last Post: 10-05-2015, 09:24 PM
  2. Which Cutter? Pixmax or Liyu
    By sharkovios in forum Vinyl Cutters
    Last Post: 24-10-2013, 12:03 PM
  3. got my liyu cutter, questions...
    By soulclaimed in forum Vinyl Cutters
    Last Post: 10-02-2013, 10:14 AM
  4. can liyu cutter do this and what should i charge???
    Last Post: 22-10-2012, 07:45 PM
  5. Cutuk DC330 vinyl cutter/Craftmate 330 cutting problem
    By Photo-Lite in forum Vinyl Cutters
    Last Post: 15-02-2012, 04:56 PM
Results 1 to 8 of 8
  1. #1
    Member
    Join Date
    Nov 2012
    Location
    Durham
    Posts
    73
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Liyu Vinyl Cutter Problem
    Hi, I've had a Liyu vinyl cutter for 4 years, bought from Signzworld. Never had a single problem until today. Now, I have areas where it looks as though the pressure of the blade, or depth of cut has reduced, meaning that when it comes to weeding, the vinyl just tears in certain areas. In some places on the vinyl, the blade does not even cut at all. Anyone had a similar problem? I have replaced both the blade and blade holder without any success.
  2. #2
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,590
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    Check different usb cable.
    <-- How To Print Stuff BLOG
  3. #3
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Not sure about the Liyu, but have you tried flipping the cutting strip (the horizontal strip below the blade)? After 4 years of use it may have become uneven.
  4. #4
    Member
    Join Date
    Nov 2012
    Location
    Durham
    Posts
    73
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorted - good old WD40... Thanks for the replies.
  5. #5
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Great, but remember WD40 is essentially penetrating oil and not a lubricant, so maybe a drop of light oil will prevent that happening again.
  6. #6
    Member
    Join Date
    Nov 2012
    Location
    Durham
    Posts
    73
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Red face
    Quote Originally Posted by webtrekker View Post
    Thanks. Will do. It was Mark at Signzworld who suggested it, very helpful.
  7. #7
    Junior Member
    Join Date
    May 2021
    Location
    Mexico
    Posts
    3
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think you have a damaged the long ribbon cable. put the carrier in start and then put enter.
    then you advance the carrier with the arrow little by little. the blade must be up and if at any time it goes down to the cutter floor, it is because there is no voltage and the cable is damaged. It costs about 35 dlls in China.
  8. #8
    Senior Member Mrteajunkie's Avatar
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,088
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Manuel V View Post
    This post was 4 years old and already solved.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
