User Tag List
Similar Threads
  1. ST3042 - Spare Parts
    By socialgiraffe in forum 3D Sublimation
    Last Post: 17-10-2023, 05:09 PM
  2. 3D sublimation ST3042 issue?
    By ATOJAR in forum 3D Sublimation
    Last Post: 07-05-2017, 03:52 PM
  3. ST3042 tripping RCD
    By paulswanton in forum 3D Sublimation
    Last Post: 29-08-2016, 09:50 PM
  4. 3D Sublimation ST3042
    By ex0rcist in forum 3D Sublimation
    Last Post: 05-03-2015, 02:58 PM
  5. Replacing thermostat on Aadkins press? ASAP!
    By justme in forum Heat Presses
    Last Post: 23-03-2011, 07:09 PM
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Junior Member
    Join Date
    Mar 2016
    Location
    Milton Keynes
    Posts
    5
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ST3042 thermostat
    Hi
    Does anyone know where I can source a replacement thermostat for an st3042 - stuck on 19 degrees when warming up then trips RCD so guessing it may be thermostat (unless anyone knows better)
    Thanks in advance (and hope)
  2. #2
    Member
    Join Date
    Dec 2015
    Location
    FR
    Posts
    173
    Downloads
    2
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    From Sunmeta (the maker), it's quite cheap. I have their pricelist and contact details if you want (PM me).
  3. #3
    Junior Member
    Join Date
    Jun 2018
    Location
    Isles of Scilly
    Posts
    16
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the same problem machine not heating above 105c after machine went bang!
    I have the same problem so I think I require a new thermostat. Just went onto http://www.sunmeta.com, but can't locate a thermostat
    in their listed products, but have emailed their sales.
  4. #4
    Junior Member
    Join Date
    Mar 2016
    Location
    Milton Keynes
    Posts
    5
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    A new thermostat solved the issue for me. It only cost be a couple of pounds. I would suggest getting a few as the postage costs are quite high. Also you might want to consider getting a spare mainboard at around £15 in case it’s something more serious. Their sales department are very efficient02 main board
    3D-14 heating sensor
  5. #5
    Junior Member
    Join Date
    Jun 2018
    Location
    Isles of Scilly
    Posts
    16
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi Paul,
    Thanks for replying, I take everything you said on board. I made another attempt today at printing a plate in my machine.
    I removed the vacuum section and put a plate into silicon plate clamp. I took a long time to get the temperature up
    195c, in fact it carried on past to 205c. In getting there the temperature went up and down. In fact when it started
    it claimed the temperature was 105c!? After cooking my plate for 6 mins. I literally cooked it. The paper went brown,
    stuck to the plate, the image brown and the plate cracked! So clearly getting hotter than it says. I won't do this
    again as I will probably ruin the machine altogether.
    I did removed the cover at the back to inspect as that is where the bang came from last night. Not the vacuum pump
    as this still works fine. Only about 3rd time I have used the machine, but out of warranty as not used for a year
    due to Corvid etc. Could detect no flash marks. Maybe the bang was in the lid, but it would have to be toward the back.
    I take it the thermostat is in the lid? Occurred when I pressed the heat button once, so had not activated the bottom
    heating element only the top one.
    Hopefully I will get a reply to my email tomorrow and will purchase a new control panel just in case etc.
  6. #6
    Junior Member
    Join Date
    Mar 2016
    Location
    Milton Keynes
    Posts
    5
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do you get the same issue with excess temperatures with just one heating plate? Ironically I’ve also got the ST-420 model as well and experienced the same issue a couple of weeks ago. I heard a bang and the top plate temperatures went off the scale. I replaced both the temperature sensor and the top heating plate but it didn't resolve the issue. The machine starts to beep when it reaches temperature but doesn’t stop heating and also there seems to be a 50 degree difference in readout vs external laser temperature check. Hopefully someone with more experience can shed some light on this and help us both. My machine also has light use like yours.
  7. #7
    Junior Member
    Join Date
    Jun 2018
    Location
    Isles of Scilly
    Posts
    16
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The experiment I conducted today also showed the temperature continuing to rise after the machine began to bleep. Took an awful long time to get there. because it would fall keep falling
    by 20 degrees then starting rising again. At one stage I didn't think it would get past 130c as it reached this temperature 3 times then falling back before passing it.
  8. #8
    Junior Member
    Join Date
    Jun 2018
    Location
    Isles of Scilly
    Posts
    16
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Still no near to getting thermostat etc.
    Still not got any where with getting a thermostat from Sunmeta. Had an email 3 days ago asking where I bought my machine from?
    Since replying to that nothing?
  9. #9
    Junior Member
    Join Date
    Jun 2018
    Location
    Isles of Scilly
    Posts
    16
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi Paul, Do you know anywhere else I might purchase the thermostat etc. Sunmeta have refused to sell me one or help me at all!?
    They said I they won't help me because I didn't purchase the machine from Sunmeta. I then asked the contact Jim King if he could tell
    me where I could purchase one and basically no reply after several days. Not exactly impressed with Sunmeta :-(
  10. #10
    Junior Member
    Join Date
    Mar 2016
    Location
    Milton Keynes
    Posts
    5
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi - that’s surprising - I had nothing but help when I contacted them (granted in was back in 2017). They have many sales email addresses (i used sales09@sunmeta.com - Lisa Wu)
    The parts you need are 3D-02 for the main board and 3D-14 for the heat sensor - should cost around $20 but will probably cost another $20-30 in postage
Posting Permissions
  • You may not post replies
  • You may not edit your posts
