User Tag List
Similar Threads
  1. Mugs in Halogen Oven?
    By Stitch Up in forum Mug Presses & Ovens
    Last Post: 20-07-2016, 04:54 AM
  2. 3D in a halogen oven
    By Quinsfan in forum General Dye-Sub Chit Chat
    Last Post: 01-11-2014, 10:09 PM
  3. Size of Halogen oven
    By swimwivsquid in forum Mug Presses & Ovens
    Last Post: 11-05-2014, 07:09 PM
  4. Halogen Oven
    By steve 1 in forum Mug Presses & Ovens
    Last Post: 14-01-2013, 02:22 AM
  5. JML Halogen Oven for mugs
    By what a mug in forum Printers
    Last Post: 26-10-2011, 09:41 PM
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
  1. #11
    Premium Member SciArtImages's Avatar
    Join Date
    Jul 2011
    Location
    York
    Posts
    112
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have used a halogen oven for years - I found early on that I needed to use the extender ring to prevent scorching as it moves the intense heat further away from the mugs. I find 4 mugs take 20 minutes (though this is currently a bit variable as I think the thermostat on mine is on the way out so will replace the oven in the new year).
    Try the extender ring to see if this prevents scorching.
    Neil.
    Science meets Art - microscope photographs revealing the beauty of the world around us.
  2. The Following 2 Users Say Thank You to SciArtImages For This Useful Post:
    Mach-One (21-09-2018), webtrekker (13-12-2017)
  3. #12
    Member
    Join Date
    Oct 2017
    Location
    Shipley
    Posts
    49
    Downloads
    2
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by webtrekker View Post
    Ok. I've done a test with 3 mugs in the oven and, I have to be honest here, results were disappointing. The reason was because, when I placed all 3 mugs into the oven, the temperature dropped way down to 150 deg C on my thermometer, so I waited until it had risen to around 180 then timed the process for 15 minutes, which I thought should be about adequate for the 3 mugs.
    All 3 were scorched, and the blacks were brown. So, I need to make more tests, but they will be after Christmas as I don't want to deplete my supply of mugs too much at the moment.
    Onwards and Upwards!
    Oh no, that is disappointing.
    My sleeves should be here in the next week or so, so I will have a play myself, ut with just 1 mug at a time lol initially.
    Im absolutely positive you will get there with this - you always seem to get the results you want.
    On another note - I love reading your posts, and you are incredibly helpful - so, thank you very much
    Terry
  4. The Following User Says Thank You to TerryQ For This Useful Post:
  5. #13
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    [User Deleted]
  6. The Following User Says Thank You to webtrekker For This Useful Post:
  7. #14
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    [User Deleted]
  8. #15
    Join Date
    Jul 2011
    Location
    York
    Posts
    112
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, I just bring it up to temp and then 20 minutes from then, no waiting for it to come back up to temp. But as I said it can vary a bit (probably due to dodgy thermostat). If you cut your paper the way that I do so that it overhangs the top of the mug a bit once clamped you can tell by the way this darkens when the mugs are going to start to scorch. But the extender ring should help loads.
    Neil.
  9. The Following 3 Users Say Thank You to SciArtImages For This Useful Post:
    Mach-One (21-09-2018), TerryQ (13-12-2017), webtrekker (13-12-2017)
  10. #16
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Cheers Neil. Some handy tips there.
  11. #17
    Member
    Join Date
    Dec 2016
    Location
    Abergavenny
    Posts
    257
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    You need to be a bit careful with halogen when you measure temperature because of the way that halogen heat works.
    Halogen lamps heat up solid objects and not the air like normal ovens. This means your mugs will heat up quicker than the surrounding air temperature and your thermometer will measure 180C only after the mugs have heated up the air to the correct temperature.
    I tend to start the timing once I put the mugs in because the mugs will start warming once the halogen lamp comes on.
    20 minutes for 4 mugs, I make sure the handles point in the middle and there is plenty of room for air flow. I always use an extender ring.
  12. The Following 3 Users Say Thank You to Customprintwales For This Useful Post:
  13. #18
    Member
    Join Date
    Oct 2014
    Location
    Leicester
    Posts
    174
    Downloads
    8
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    After following this thread I went and bought a halogen oven from Amazon. £28. Set it up with the extender and every mug perfect. 4 mugs at 180 for 15 minutes. The oven is 1300w. Gonna buy another couple now. Thanks for the thread.
  14. The Following 3 Users Say Thank You to Andysam26467 For This Useful Post:
    Mach-One (21-09-2018), Triple9 (27-01-2018), webtrekker (14-12-2017)
  15. #19
    Junior Member
    Join Date
    Dec 2017
    Location
    Glasgow
    Posts
    12
    Downloads
    3
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    would never have thought about using one of these.
    Just waiting on my replacement mug press arriving..so I can finish an order..
  16. #20
    Member
    Join Date
    Nov 2016
    Location
    Towcester, Northamptonshire
    Posts
    147
    Downloads
    1
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I have 2 mugs to do to start with what temp and how long to people recommend 11oz
Posting Permissions
  • You may not post replies
  • You may not edit your posts
