Hi folks
Anyone know if its at all possible to get sheets of air freshener sublimation blanks that I can cut into a custom shape using my cutter then sublimate onto?
Cheers
Hi folks
Cheers
I've been looking for the same thing and haven't found them yet. I'll be interested in the response to this thread.
Surely the heat off the heat press will damage the airfreshener smell and make the fragrance not last as long.
You would probably need to print/cut the board first, then add the fragrance after.
You normally get them pre cut John. After pressing them you dip them or put drops inside the plastic bag after is decorated.
<-- How To Print Stuff BLOG
Directdesignsupplied.co.uk
I've looked for the backing felt/board (polyester coated) for these, maybe a4 sheets but cant seem to find any, I was thinking about putting them through the cameo but I think the board maybe to thick for the machine to handle.
I know bms supply the rectangular air freshners, whether these could be cut into smaller custom shapes I don't know?
John, After they are cut and printed the essential oils are added onto the actual print, just a couple of drops then whack them in a sealed bag.
Angol, where did you get yours from, is this coaster material or is it the actual air freshener board?
