User Tag List
Similar Threads
  1. Roland Versaworks /Roland Library Swatches
    By Focus1 in forum Printers
    Last Post: 12-03-2017, 07:36 PM
  2. Versacam Users With White Ink Configuration
    By socialgiraffe in forum General Dye-Sub Chit Chat
    Last Post: 24-11-2015, 09:56 PM
  3. Replies: 45
    Last Post: 10-05-2013, 09:34 PM
  4. refillable cartridge
    By scottmurray89 in forum Printers
    Last Post: 11-02-2013, 10:10 PM
Results 1 to 8 of 8
  1. #1
    Senior Member logobear's Avatar
    Join Date
    Feb 2010
    Location
    Newcastle upon tyne. UK
    Posts
    1,669
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Roland Versacam WHEN to change the cartridge?
    Our SP300i says magenta low, - both through the rip and on the printer screen, but the cart still has some ink sloshing about in the bottom.
    It has succcessfully printed a few metres in this condition, I am wondering how best to manage the cart change?
    I guess is is pretty serious to run dry, but there does still seem to be some sloshing about.
    Any advice?
  2. #2
    Member
    Join Date
    Jul 2017
    Location
    PONTYPRIDD
    Posts
    190
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    We do have an SP 300 though only in reserve nowadays as we use a 12 cartridge 1600 mm for our daily work. The cartridges will run for ages when they show the low warning.
    If possible order up spares of the colours running low but wait until completely empty before changing. If your RIP is Roland Versaworks and the software is an up-to-date version it will calculate if it has enough ink to complete the job once the file is ripped. If it says not enough you can keep an eye on it while it runs out. When it does become empty it sounds an alarm every several seconds and you simply slot in the replacement and press "continue" on the RIP.
    It won't mess up your print, it will just resume without fuss.
    If you don't have a spare and need to finish a job try removing the cartridge, shaking from side to side slowly and re-insert it. There is probably enough to get you out of trouble.
  3. The Following User Says Thank You to StellaD For This Useful Post:
    logobear (23-03-2018)
  4. #3
    Join Date
    Feb 2010
    Location
    Posts
    1,669
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Hi Stella,
    perfect answer.
    I got full set of spare.
    I know the 300i is a bit long in the tooth, but we wanted to run ESL-3 inks as they have the reputation for longest life on garments, and that inkset is not available on newer machines.
    phil
  5. #4
    Member
    Join Date
    Mar 2015
    Location
    Oxfordshire
    Posts
    532
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Remove and gently tip a cartridge back and fourth, there is a little piece of plastic that you will see going in and out of the cartridge body at the front of the cartridge, that lets the machine know when it's ink has run out.
  6. #5
    Join Date
    Feb 2010
    Location
    Posts
    1,669
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Spoke with Roland tech today, confirmed fine to run until machine stops. wont harm.
  7. #6
    Member
    Join Date
    Mar 2015
    Location
    Oxfordshire
    Posts
    532
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My magenta 'ran out' today with machine beeping, so took it out, shook back and fourth then tipped towards input end so the plastic tang goes back in and it's using up the last of the ink in it. I'll replace it tomorrow.
  8. #7
    Member
    Join Date
    May 2014
    Location
    Midlands
    Posts
    223
    Downloads
    5
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    In the past I have cut the little tab off, ordered more ink, that took 3days to land and was still printing fine
    Make it idiot proof and someone will make a better idiot. He who laughs last thinks slowest!
  9. #8
    Member
    Join Date
    Mar 2015
    Location
    Oxfordshire
    Posts
    532
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think they err on the side of caution and quite a bit of ink is left and wasted
Posting Permissions
  • You may not post replies
  • You may not edit your posts
