User Tag List
Similar Threads
  1. Cheep Chinese Heat Press Vs Quality Branded Heat press
    By Ravisteam in forum Heat Presses
    Last Post: 06-01-2017, 07:36 PM
  2. Running ink issues after pressing
    By paul 44 in forum Printing Problems/Issues
    Last Post: 25-12-2015, 01:51 PM
  3. Cleaning the heat platen
    By Bob @ Prestige in forum Heat Presses
    Last Post: 21-01-2015, 09:17 PM
  4. Heating up but not stopping at set temp.
    By Quinsfan in forum Heat Presses
    Last Post: 18-11-2013, 12:39 PM
  5. Cleaning heat press top platen?
    By Kaz in forum General Dye-Sub Chit Chat
    Last Post: 28-05-2010, 08:53 AM
Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
  1. #11
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,384
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    Hi Vis vests are very difficult items to press. Take it from someone who is currently around 500+ a week :-)
    Covering with grease proof paper etc helps but it will never get rid of the problem completely. Even having a separate heat press will not solve the issue as you will get migration from vest to vest.
    You need to establish the perfect time and temperature for sublimating versus migration of the dye in the vest. As an example, I have two current times and temps depending on who is pressing
    One is 65 seconds 172 degrees, the other is 45 seconds 175 degrees. Although the second one does migrate the dye a tiny bit.
    Obviously different presses, vests and ink will have different times etc.
    As a work around you can press all your hi vis stuff at the end of the day. Once you have finished, crank up the temp to 200 and wipe with a cloth to remove all the dye. You can also get a can of air spray to remove it. Once wiped thoroughly, press with an old WHITE cloth (no image) ust to check you have got everything and then turn the machine off ready for the morning
  2. The Following User Says Thank You to socialgiraffe For This Useful Post:
    Fletcher (09-07-2018)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
