User Tag List
Similar Threads
  1. Applying graphics onto 2D wood figures (help needed)
    By Alburt in forum Member to Member Offers/Requests
    Last Post: 18-05-2017, 03:46 PM
  2. Replies: 3
    Last Post: 03-04-2012, 07:34 AM
  3. Suncreens splitting ... ?
    By AdamB in forum General Dye-Sub Chit Chat
    Last Post: 13-06-2011, 10:27 AM
  4. applying vinyl with an iron?
    By AdamB in forum Vinyl & Flock
    Last Post: 19-10-2010, 05:14 PM
  5. Vehicle Graphics!
    Last Post: 14-08-2010, 03:21 PM
Results 1 to 9 of 9
  1. #1
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,253
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    Applying/splitting graphic over vehicle panel edges
    Currently working on a small van design, bit of a noobie question coming up!
    I have a print and cut design to go across the back door panels that will cross over the centre gap where the doors open. Obviously I will lose a small amount of the design each side where it wraps over the edges. Do I allow for this in the design or do I just cut off and it looks ok?
  2. #2
    Member
    Join Date
    Jul 2017
    Location
    PONTYPRIDD
    Posts
    190
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Try and design so that small text misses the gap - bear in mind that many small vans have rear doors which split 2/3 , 1/3 rather than in the middle.
    Apply as though there is no gap and then slice through with a blade.and either trim back to the edges or wrap the excess around the door edges. Those edges will need to be cleaned on the inners to make sure the adhesive grabs and holds.
  3. #3
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,253
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    That'w what i was trying to do but doors are 1/2 split and text won't line up with gaps in the right place.
  4. #4
    Member
    Join Date
    Jul 2017
    Location
    PONTYPRIDD
    Posts
    190
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Can you adjust the kerning between letters to create space?
    Otherwise tell the customer straight that it needs to be changed.
    Customers are very good at saying their layout is fine but only complain after it has been cut and fitted.
  5. #5
    Senior Member Quinsfan's Avatar
    Join Date
    Nov 2013
    Location
    Bookham
    Posts
    1,196
    Downloads
    1
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    If you can’t move the text then just apply the vinyl and cut at the join.
    As a previous post said just make sure all surfaces are clean.
  6. #6
    Join Date
    Nov 2013
    Location
    Bookham
    Posts
    1,196
    Downloads
    1
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
  7. #7
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,253
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    This the graphic I'm proposing, it will be a single piece print and cut (laminated) so as mentioned above I guess just slitting down the middle and wrapping slightly over the clean edges will suffice.
    I tried adjusting text etc. but nothing is working for me.
    Attached Images Attached Images
  8. #8
    Join Date
    Nov 2013
    Location
    Bookham
    Posts
    1,196
    Downloads
    1
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Don't rely on the outlines for the panel size. I would do a paper template of the rear panel. Print the whole image as a rectangle and then use the template to cut to shape. Alternatively if you have wrapcut or similar you could use that.
    https://signtradesupplies.co.uk/appl...less-tape.html
  9. #9
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,253
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    Yes, that was the intention, this is just to show to the customer :-)
    Never seen that stuff, looks very useful thanks.
    Cheers :-)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
