User Tag List
Similar Threads
  1. possible stupid question alert!! how does sublimation work, exactly?
    By TQfan in forum General Dye-Sub Chit Chat
    Last Post: 05-03-2018, 01:23 AM
  2. Probably a stupid question about cheap ink
    By ArtyGamer in forum Printers
    Last Post: 01-06-2014, 02:32 PM
  3. Possible stupid question :)
    By michc in forum Copyright and other legal matters
    Last Post: 25-04-2014, 12:11 AM
  4. Another beginners question or im just stupid.
    By Dave271069 in forum General Dye-Sub Chit Chat
    Last Post: 23-05-2012, 09:11 PM
  5. Stupid question - but one to which I do not know the answer!
    By Robert in forum Mug Presses & Ovens
    Last Post: 06-01-2010, 11:50 AM
Results 1 to 4 of 4
  1. #1
    Premium Member
    Join Date
    Feb 2017
    Location
    Reigate
    Posts
    44
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    May be a stupid question but...
    ... does anyone know of a way to remove or reduce an unwanted faint ink bleed on a substrate?
    I am trying to learn how to print bowls using a wrap and oven system (a setup I ditched ages ago as too unreliable and WAY too much faff). Keep getting perfectly usable bowls but with a faint ink bleed here and there, which is very annoying.
    Is there any way to re-heat / bleach out / draw out? the staining?
    TIA
    Ruth
    Attached Images Attached Images
  2. #2
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Hi Ruth. Just a couple of quick questions:
    Can you show a picture of the wrapped bowl before placing in the oven?
    What type of oven are you using, and the times and temps?
  3. #3
    Premium Member UK Printed Mugs's Avatar
    Join Date
    Aug 2014
    Location
    Poole, Dorset
    Posts
    2,114
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Ensure all sides of paper is taped to prevent gas escaping and use sheet of silicone paper between paper and wrap (cut to same wrap size) so old ink on wrap doesnt get back onto substrate. Might help.
  4. #4
    Premium Member
    Join Date
    Nov 2011
    Location
    Bishop Auckland, County Durham
    Posts
    4,280
    Downloads
    0
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    3 Thread(s)
    ... Also covering any exposed coated areas of the substrate will help reduce ink which is gassed and floating around the oven getting where it shouldn't.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
