User Tag List
Similar Threads
  1. Help required sublimation heat pressing
    By welshnutteruk in forum General Dye-Sub Chit Chat
    Last Post: 13-10-2017, 04:13 PM
  2. what do people spray on before heat pressing a sublimation picture
    By tiamaria in forum General Dye-Sub Chit Chat
    Last Post: 03-09-2015, 11:31 AM
  3. Replies: 7
    Last Post: 11-07-2015, 11:46 AM
  4. Replies: 2
    Last Post: 31-01-2015, 11:14 AM
  5. Keeping your platen clean
    By roobear in forum Hints & Tips
    Last Post: 02-08-2013, 08:40 PM
Results 1 to 6 of 6
  1. #1
    Member
    Join Date
    Oct 2017
    Location
    Denia
    Posts
    62
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Keeping heat press clean when pressing sublimation T shirts
    Hi,
    as we all know paper on top of platen below T shirt and another one on top of sublimation paper will keep the press clean. I was tired one day though of throwing so much paper / approximately 5 cents per sheet/ . So i decided to put aluminum foil below the T shirt.
    Oh, yeah. That worked. Cheaper and most of all will last days. The best thing is you will not need to change it on every shirt. The sublimation ink simply does not stick to it at all. all is much cleaner now and easier to slide the T shirts on and off. Saves a lot of time.
    It stays all the time on my lower platens, even when sublimating aluminum business cards and alu plates. And it sticks very well to the spongy silicone.
    Hope that helps.
  2. The Following User Says Thank You to Boyan For This Useful Post:
    Earl Smith (04-10-2018)
  3. #2
    Senior Member logobear's Avatar
    Join Date
    Feb 2010
    Location
    Newcastle upon tyne. UK
    Posts
    1,669
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    great tip.
    I am guessing you are using a really thick catering grade of foil, not thin domestic?
  4. #3
    Member
    Join Date
    Oct 2017
    Location
    Denia
    Posts
    62
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by logobear View Post
    great tip.
    Domestic roll of foil. 1.5euro or something like that, 30 meters
  5. #4
    Senior Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,369
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Does the aluminium not reflect heat messing around with your temperature? I remember accidentally leaving an aluminium cup in the mug press for 20 mins. When I went to press the next mug, the paper stuck to the mug. I assumed that the press had gotten too hot.
    I use an oversized teflon/ baking sheet over the platen which doesn't rip and allows the ink to be wiped off easily.
  6. #5
    Member
    Join Date
    Oct 2017
    Location
    Denia
    Posts
    62
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Post
    Quote Originally Posted by GoonerGary View Post
    No problem. Aluminum transfers heat when in tight contact. i use same aluminum between silicone wrap and paper, for mugs. At 205C and no problem.
    I sell and make 65/35 Russell T shirts at a retail location, so every mistake costs me exactly 6 euro from my pocket including ink and paper, so i learned pretty quickly some details like protect the base clean, clean dust from t shirt and cut around designs by hand to avoid even a small dot so result is perfect.
  7. #6
    Member
    Join Date
    Oct 2017
    Location
    Denia
    Posts
    62
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    PS. Where is the picture from my first post?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
